Question about Microwave Ovens
Ge profile advantium 120
The display is blank but the oven still works. Help please. We have either a SCB1000 or SCB1001
SparkGap
  • 363 Answers
SOURCE: I recently purchased this home,
The manual is available on the GE web site
http://www.geappliances.com/service_and_support/literature/
Type in the model number
Good Luck.
Posted on Aug 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Microwave (Model SCA1000DBB03)
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Oven not working; less than year old!!
No need to scan now...
We got the service manual for this model and have uploaded it to our site here to help you.
You will need the
I'm suspecting the keypad or a door switch or switch mount issue.
Also, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 26, 2008
  • 10865 Answers
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
You may consider using epoxy to "glue" the handle back into place. The epoxy will be stronger than the handle itself. If you do this get the one minute epoxy
Posted on Apr 27, 2009
dmftrucker
  • 1922 Answers
SOURCE: replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Posted on Sep 26, 2009
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
Jun 13, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Display is blank
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
Apr 16, 2014 | GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium 120 . The panel lights up I do not get an error code the timer works but it does not heat up. what could cause this
Check your power setting, making sure that you are cooking at 100%. Adjust if necessary.
It could also be a bad magnetron.
Regards, --W/D--
Jul 05, 2009 | GE Advantium 120 Convection/Microwave Oven
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
