Question about Fellowes ShredStik Shredder
Need power plug/forshreder stick - Fellowes ShredStik Shredder
Setting up fireTV stick. It's plugged in to TV and power.ts Tried all inputs on TV. None worked. What am I doing wrong???
not sure if this link will help you out.
1. The easy way (5 mins)
  1. Plug your Amazon Fire TV Stick into your TV and plug the USB power cable into a spare USB port or use the power adapter.
  2. Go to Settings. ...
  3. Go back to the homescreen and install an app called Downloader - this will be listed under the Popular Fire TV apps section.
More items...
How to install Kodi on the Amazon Fire TV Stick: 3 BEST ways to ...
how to set fireTV stick Google Search
Oct 28, 2017 | Televison & Video
How do I stop the fire stick from locking up when watch a program?
If You are powering the stick from the USB port on TV, You need to plug the power to stick from the wall plugin using adapter instead of TV's USB port. The port in most cases does not have enough power to run the stick! This will cause the stick to stop performing restart or freeze up!
Jul 13, 2017 | Televison & Video
FIRE STICK FREEZE UP WHEN WATCH A PROGRAM
If You have the power side of stick plugged into a USB port on the tv, unplug it from TV and use a wall plug adapter to power the stick! Sometimes the TV USB does don't send enough juice to the stick to give it the power it needs, which will freeze up the stick! If this is the problem, and a fix please give me a point for helping Ya! Thanks!
Does my fire tv stick need a cable box to function or can I just plug it from my tv to the electric outlets
The Fire Stick just needs a HDMI port to plug into. The ones on the tv (assuming it's a newerish tv with HDMI connections) will work fine.
Feb 03, 2017 | Televison & Video
Hi, I purchased a firetvstick but it does not respond after plugged into my smart tv. help
Check list:
1) Do you have your fire stick powered?
Connected via usb cable to a power adapter
plugged into a power strip that has the power on,
power switch is off....so on.
2) Do you have your TV input set to the correct HDMI input?
Depending on the model you may have 2 to 4 HDMI inputs.
This is the most common error.
Please make sure the input is set to the correct input
of where your fire stick is plugged in to.
3) If you have power and the input in your TV is set.
And you still have nothing.
Then your firestick might be defective.
4) If it is working, read the instructions carefully.
connect your fire stick to your wi fi and register your fire stick.
Then enjoy!!
Aug 30, 2016 | Amazon Fire TV Stick
Does it have a USB port to connect a Ruko stick? If not, how can I connect it?
The KDF-42WE655 does not have a USB port. The current Roku sticks plug into the HDMI port on the TV. You will need to use the power adapter that came with the unit. Plug the USB cord (mini or micro USB) into the back (or side) of the Roku Stick and then plug the power adapter into a nearby power outlet. (It's a 5V 1A DC power adapter.) Roku sells this adapter separately on their Accessories page: https://www.roku.com/accessories . It's ~$10. If you have mounted your TV such that the power outlet is hidden behind the TV, you'll get to the outlet or use another nearby outlet. (Make sure to avoid a tripping hazard if you use an extension cord or power strip to increase the number of available outlets.)
I hope this helps.
Jul 26, 2015 | Sony Grand WEGA KDF-42WE655 42" Rear...
Will not connect to tv do you have to disconnect cable to get menu screen on fire stick
plug stick into hdmi on tv,tune tv to hdmi 1 or 2,plug power cord into stick and outlet,push center button for 5 seconds
Mar 08, 2015 | Amazon Fire TV Stick
Why won't Amazin Fire Stick or Google ChromeCast work on my Samsung led 3D tv? Model UN46FH6030FXZA
Make sure your Chromecast or Fire stick are not only plugged into the tv, but also plugged into a power source. You may need to try to plug them directly into the wall rather than the usb on the TV itself.
Nov 21, 2014 | Televison & Video
Will not turn on at all
It time for new power supply.
Sep 11, 2011 | HP Compaq nc6120 Notebook
I added a 512mb stick to my ibm t30 think pad and one port is bad
You can plug a USB hub into the working USB port on the computer. The USB hub can have several ports so you can plug in several USB devices.
I suggest you get a powered USB hub because if all the devices that you plug into this hub exceeds 500mA then your computer's USB port will stop working because it could not supply enough current.
You will not need to plug in the power adapter into the hub if the device/s do not overload the computer's USB port.
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
