Question about BenQ Computers & Internet
Benq E2200HD monitor shuts down after flickering.
Displays 3 seconds only when pressing manually on green light button but seems to be loading.
iqbal_del
  • 655 Answers
SOURCE: Monitor Flickering
If you have some electrical equipments like CVT, UPS near to your monitor, please put them away. If the flickering is due to the maganetic interfearence then it will solve your flickering of screen. and even after this if you are not able to use your monitor buttun then please call your technical expert b.coz your monitor may got some physical problem.
Thanks
Iqbal
Posted on Mar 08, 2008
  • 152 Answers
SOURCE: LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Posted on Apr 06, 2009
romsky79
  • 822 Answers
SOURCE: Monitor displays desktop for a short while
this kind of trouble is very common to all LCD monitors. your inverter is shutting down. please check all capacitors at the power supply some are badged or blown on top due to hot pressure inside.
Posted on Aug 17, 2009
ag66339
  • 127 Answers
SOURCE: BenQ E2200HD monitor won't output sound
You do not have the necessary drivers installed. Go to the manufacturers website and download and install the recommended drivers.
Posted on Sep 22, 2009
budmrtn
  • 11361 Answers
SOURCE: Have a dell e177fp monitor. When I power on it
You probably have failure in the inverter circuits due to shorted transistors, bad solder joints, bad caps. Please see my pictures here so you will know what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Replacment board:
http://www.lcdrepair.us
Please post back so it may help other people with the same problem.
Posted on Apr 09, 2010
Testimonial: "Thanks bud."
Flashing
This is a very common symptom of a failure of the filter capacitors in the power supply board. The monitor is repairable, you just need to replace the 7 capacitors on the power supply board. Here is information on the board and the capacitors needed to repair it.
http://www.ccl-la.com/catalog/product_info.php?products_id=331
May 08, 2013 | BenQ E2200HD 21 inch LCD Monitor
Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Apr 08, 2010 | BenQ E2200HD Monitor
How do you get rid of a stuck green pixel on a benq e2200hd? ive already tried software fixes
Missing pixels are common on any LCD type of TV. The only way to get rid of it is to replace the panel itself. Do you have any kind of warranty?
Oct 24, 2009 | BenQ E2200HD Monitor
Sep 21, 2009 | BenQ E2200HD Monitor
Aug 17, 2009 | BenQ FP71G 17" LCD Monitor
Benq fp91g+ monitor doesnt stay on
Hey...Superb****,
It's seems your monitor it *******...Hehehe... Due to busted backlight inverter.
Need to replaced a new one or repaired it.
Jul 09, 2008 | BenQ FP91G+ 19" LCD Monitor
Monitor Flickering
Thanks
Iqbal
Mar 08, 2008 | BenQ FP567s 15" LCD Monitor
Monitor displays breifly then goes to blank screen
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
Computers & Internet Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
