Question about BenQ Computers & Internet
Benq E2200 monitor black screen
Shuts down after flickering only displays 3 secs when press green button on bottom right corner.
Mark_Webber
  • 472 Answers
SOURCE: screen working and after 2 sec screen black
On your power board you will have a faulty surface mount fet with 8 legs that controls the backlights.
There are 4 of these, but if any of them fail the protection circuit turns them all off.
Best best is to get it to a local technician for repair. It is not an easy task unless you have the right equipment.
Hope that helps. =)
Posted on Apr 09, 2008
freetek
  • 5568 Answers
SOURCE: BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Posted on Nov 01, 2008
SOURCE: HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
I have the same problem. I leave the computer on for awhile to warm up the screen. I don't know why, that seems to help. I turn off the screen on the bottom right and do that a couple of times. Behind the screen I unplug and plug and unplug and plug the screen in again. After it gets going, it works all day. But at night I like to turn off the computer to rest. So I have to do this every morning.
Posted on Mar 26, 2009
  • 1684 Answers
SOURCE: ACER Al1916W goes blank in 3 seconds. It shows
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
  • 3 Answers
SOURCE: BENQ Q7C4 monitor shuts down after 5 seconds of
BENQ Q7C4 monitor shuts down after 5 seconds of login screen display
Posted on Jul 08, 2010
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
Monitor's display is shifted up and right so that there is just black space to the left and all along the bottom whereby cutting off the display. cannot see bottom menu bar.
One of the buttons on the front of you monitor (bottom right hand corner of the bezel) is a menu button. Press that then using the the arrows up and down buttons go the the horizontal and vertical positioning option. Once chosen move the display as desired.
You could also press the Auto (config) button, that may do the same for you.
May 17, 2010 | Acer AL1912 19" LCD Monitor
Pioneer AVH-P4000DVD video goes black after 2 or 3 seconds. I can touch screen and it comes back but for only a couple of seconds. Audio is fine
You pressed the Disp. Off button on the bottom left corner. If you press it again it will stop turning the display off.
Oct 25, 2009 | Pioneer AVH-P4000DVD Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Benq computer monitor shuts down after standby in energy saving..
There are 6 (reduced quality) capacitors in the BenQ Q9W5 which cause the screen over time to 'fail to sync' when turning on or resuming from standby.
They are;
4x 470uF 35v, and
2x 1000uF 16v.
I recommend the following replacements if you are in Australia (the ones I purchased from Jaycar only lasted 12 months);
(470uF) http://www.altronics.com.au/index.asp?area=item&id=R4865
(1000uF) http://www.altronics.com.au/index.asp?area=item&id=R5182
Mar 24, 2009 | BenQ Computers & Internet
Screen working and after 2 sec screen black
Hope that helps. =)
Dec 14, 2007 | BenQ FP92W LCD Monitor
Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Dec 10, 2007 | BenQ FP71E 17" LCD Monitor
Computers & Internet Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
