Question about Drills
I HAVE A JCB CD-20LI BATTERY DRILL THAT HAS JUST STOPPED WORKING THE BATTERYS ARE FINE.
HI THE DRILL STOPPED WORKING WHEN DRILLING A 20MM HOLE TRU SOME WOOD, THE BATTERYS SEEM FINE. THEY ARE FULLY CHARGED AND I HAVE TRIED THEM BOTH.
  • 313 Answers
SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
Posted on May 24, 2008
emissionwiz
  • 76122 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
  • 74 Answers
SOURCE: can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Posted on Feb 10, 2009
fisherman816
  • 66 Answers
SOURCE: my ryobi 14.4v cordless drill won't turn on. The
The problem is most likely the switch.http://www.ereplacementparts.com/ryobi-cordless-drill-parts-c-7931_8051.html
Posted on Nov 07, 2009
  • 583 Answers
SOURCE: I have a Black and Decker 12V CD12C cordless
no i dont think you are doing any thing wrong ,it is typical of the product you bought .
Posted on Nov 17, 2009
Why does my Makita 6011D cordless drill not work when my charged battery in installed? The battery does work on my Makita saw so I know it is not the battery.
Look inside where the Battery terminals connect.
THey are flat metal springs inside the drills Battery hole.
Make sure the are not compressed down causing them not to touch the battery terminals of the battery.
ALso check the Brushes on the drills motor they may need replacing...
Selvol
Jul 06, 2014 | Makita 6011DW Battery 1500mAh, 12V, Ni-Cd
Hitachi dv18dvc drill just stopped battery fine
You can test the battery by using a voltmeter.
Set the voltmeter to DC and to read up to 20 volts.
If its getting a reading, then the trigger switch most likely shorted out. If not, then the battery is defective.
Feb 08, 2013 | Hitachi DV18DVC 18V Cordless Hammer Drill
Makita dril 18v stopped working
check switch it may have over heated and burned out
Oct 22, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drill completely stopped working. Bad smell from battery. Charged up the second battery and plugged it in. In three seconds, it started smoking very badly. I removed it. The drill worked with second...
The only way to tell if you can fix it is to take the drill apart...
Look for two wires melted together...my guess is that they got too hot and melted together inside the drill... separate and insulate and you should be fine...
heatman101
May 21, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My JCB 18V cordless drill is not working when you press the trigger. The battery is fully charged any ideas please.
It's probably the switch; mine judders and works kind of. Slight burning smell coming from it, dismantled it to discover that the switch has started to burn out, so far no luck finding a replacement.........
JCB are totally useless, no help from their support phone number!
Sep 15, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My hitachi drill is working funny
hi
try to charge the battery at full level and see what happens then.
regards savumihai71
Dec 13, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Drill stopped work ing when hot. One drill we bought stopped after 10 6mm holes. The others work when you pull the trigger and then sometime they don't.
Sounds like a burned out motor.
Sometimes you can replace the brushes and make them work again.
When operating that drill, make sure that you are not overheating the motor.
Depending on the material that you are drilling, you may need to use the drill on a slower speed in order to not overheat the motor.
Another way is to have more than one drill, and switch to a cool one as soon as you notice heat on the in-use drill.
If your drill is battery powered, stop using the drill and change the battery as soon as the battery dies enough to slow the speed of the drill.
Operating the drill under reduced power is very hard on the motor for several reasons.
Oct 28, 2009 | Milwaukee Tool Drills
Aug 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
