Question about Intel D34223-002 Socket 775 Aluminum Heat Sink & 3"" Fan w/4-Pin Conne
2 Suggested Answers
SOURCE: How do I remove the Intel Socket 775 heat sink?
in the below given website there is an example how to remove it with the images please refer to that :
http://www.o0o.it/mini/
if you want more clarification you can refer to the video too from the below given site :
http://eshop.macsales.com/tech_center/index.cfm?page=Video/mini/med.html
NOTE: you need heatsink paste to put it afterwards when refit the heatsink so arrange the heatsink paste first and then you can open it ....
thank you
any more queries you can contact me
rate my solution..
Posted on Sep 11, 2008
Need Audio driver for intel e18764
You need to give us the motherboard number not the processor number.
Aug 13, 2012 | Intel E18764-001 Socket 775 Aluminum Heat...
Intel Motherboard DG31PR overheat Problem it start at 68'c & goupto 75'c system is very slow cpu temperature range from 45-52'c
hi..hope ur a pro b4 handling core hardware components like cpu..
well d prob u described can b any one of d following:
i) the cpu fan- a) can be dirty..clean throughly..
b) look if any of the clips mounted into d main board is damaged..
c) try replacing d whole fan..
ii) the heat sink- may b dirty too..clean using a blower
iii) heat sink compund- ie a white paste rendered with a thin film between d cpu n d heat sink..it is seemed to b dried up..clean it using a cloth n re-apply it (available in chip-level spare market)
n.b.: b very careful b4 opening cpu fan n cpu from itz socket..
iv) open cmos utility or bios setup n in temperature settings ignore or disable cpu warning temperature..
v) c if all d electrolytic capacitors (mfd) situated in d north bridge of d main board r ok or not..
vi) download n install any cpu temperature control or cpu cooler software (dis softwares increases d fan speed as n when necessary)..
vii) if all d above fails try replacing d smps (atleast 450w)..
bt itz always better to seek intervention of ur computer supervisior or a pro..
n plz do vote n rate..
Dec 29, 2010 | Intel DG31PR Motherboard
My old heat sink and fan have screw in attatchments and the new on has the plastic pop in and 1/4 turns. Help?
Your old heat sink and fan probably works just as as good or better than that stock Intel fan and heat sink. If your computer case does not allow access to the rear of the motherboard you are going to have to remove the motherboard to pull the back plate that was used to attach your old heat sink and fan. To install the Intel fan turn the pins until the screwdriver slot is perpendicular to the fan shroud (the tip of the arrow is furthest out), then push in any 2 opposite sides at the same time into the motherboard. You will here them click in. Repeat for the other 2 pins.
Dec 22, 2010 | Intel Socket 775 Heat Sink and Fan up to...
I am trying to determine what cpu pentel 4 (D) 3.0
Gateway 831GM Pentel 4(D) is for socket 775
Jul 25, 2010 | Gateway 831GM PC Desktop
The bracket clip that holds the fan down broke. Is there a fix or do I buy a new fan?
If you are innovative enough one can improvise by simply hold the fan to the heat sink with copper wire in case only one bracket is broken. The fan only requires to be on the heat sink to remove heat from the processor. Otherwise the fan & heat sink as one sealed unit only. Else try out the junk yard and see if you can hunt for one where PC's are dumped !
However if you want your PC to last for 2-3 yrs more, trouble-free, then my recommendation would be to replace the fan+heat sink unit, 'cos if the heat conducting paste between the processor & heat sink, if disturbed cannot be replaced to its original capacity & the processor will overheat and the PC will auto shut down repeatedly, till the processor is damaged permanently! .............................sodeep
Nov 12, 2009 | Foxconn CPU Cooler Fan CPU Fan
Finding information to aid replacing cpu cooler
Yes, some do come with push pins like that instead of screws so that it is easily removed and installed also. Usually the push pin ones are cheaper. The cpu and heat sink are compatible by cpu socket type.
Apr 04, 2009 | Fujitsu Siemens Computers & Internet
Upgrading the cpu and heat sink and fan
All the factory fitted CPUs are having such heat sinks as previously u were having.
Check on the backside there will be small plastic covers where screws fit these could be removed by screw driver but u can purchase that heat sink or can use previous heatsink as well if it is working.
Feb 26, 2009 | Intel Socket 775 Heat Sink and Fan up to...
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Cant get any display through xpert vision 8800gt with msi p6ngm
is the fan on your video card working and is the heat sink for it clean this could be an overheating problem
Aug 07, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
Intel D34223-002 Socket 775 Aluminum Heat Sink & 3"" Fan w/4-Pin Conne Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
