Transcat 2000pv when hooking up to PIT though a valve. my will stay low
Can you get water in LP lines when filling RV w/ propane? Frig quit on propane,worked on electric. Had filled w/ propane two days earlier. mechanic found oily water in line; range still worked.
Yes water can do compensation build up in your propane tank. Some tanks have a drain pit on bottom reclaim propane and open the pit. If your does reclaim the propane and drain tank. If not reclaim propane and remove tank then remove filler valve turn tank over drain access water leave tank up side down over night. Put fill valve back on and mount tank. After lines are back on turn stove on leave on for 48 hours. Turn valves off and refill tank. Best of luck.
Jun 10, 2016 | RVs
What is a tappet on my Apollo DB 125cc pit bike
Hi, Cory it's the arm that the camshaft moves to open and close the valves for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
how to set valves on pitbike
Pitbike Direct How to adjust your tappets
http://mypitbike.ru/downloads/OrionAssemblyInstructions.pdf
2 Apollo Dirt Bike Reviews Youll Want to Read
125cc pit bike carby service
Mar 19, 2016 | Apollo Orion 250cc Pit Dirt Bikes Pro
2000pv heater does not get too hot
Heater core plugged up. Transfer door not opening all the way. Valve inline from radiator to heater core hoses not opening or not opening all the way.
Jun 25, 2015 | 2000 Mazda MPV
125 Pitbike keeps fouling spark plugs
Hi, Damon and the usual suspects are:
1. Dirty air filter.
2. Fuel mixture too rich or the choke has been left on too long.
3. Faulty spark plug.
4. Incorrect spark plug heat range for the engine type or service.
5. Piston rings badly worn or broken.
6. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
7. Spark plug cable weak or leaking check for spark leakage in the dark.
8. Faulty ignition coil.
9. Low RPM nonaggressive riding style.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Why Does My Dirt Bike Keep Fouling Spark Plugs
Spark Plugs Keep Fouling
http://mypitbike.ru/downloads/ThumpstarServiceManual.pdf
https://www.orionpowersports.com/pit-bike-dirt-bike-parts
http://www.ssrmotorsports.com/store/ownersmanual/pitbike/Pit%20Bike%20Owner's%20Manual.pdf
Sep 13, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Can a half inch pipe and 3/4 work
Sure you can stay in 3/4 into the house a ways. Some of my plumber friends run 3/4 all the way to the hot water tank. It increases the volume of water. This is particularly effective if there isn't much water pressure. Dropping down to 1/2 inch will increase the pressure. All you need is a 1/2" by 3/4" bushing to drop down to 1/2". I h 7_29_2014_5_47_37_pm.jpg
Jul 27, 2014 | Plumbing
How to put a pit bike egine back on
I'd start by hooking the motor back up to the frame then lift it up so you can put the top engine mount bolt in and then u just have to tighten the motor down and hook the lines back up and electrical and ur good to go.
Jun 24, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
Dishwasher will not drain
Hello, sounds like you either have a blockage in the pump or check valve. Remove the spray arm, the 4 screws on the filter and check for a blockage. If you find nothing inside the machine remove the panel at the bottom below the door. Behind this you will see the outlet pipe which is hooked up to the check valve. remove the outlet pipe and then unscrew the check valve from the dishwasher. has one the other day with a cherry pit stuck in the check valve. If you have any other questions please feel free to comment again. Also remember to turn off the breaker before working on your dishwasher. Thanks! Mike
Oct 01, 2009 | Kenmore Dishwashers
Water backs up in the floor drain during heavy downpour even thou
the sump pump shold not be run into the sanitary sewer, but if your floor drain is hooked to a sump pump pit and it doesn';t pump the water before it gets to the drain tile it could come up in the drain,, to solve the problem get a pump that the float is lower in the pit,, suggestion zoeller cast iron submersable pump cost about 100 less the install price, great low profile pump, it keeps less waterin the sump pump pit so there is less mosture
Mar 11, 2009 | Invacare Supply Group Invacare Top End...
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
