Question about GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop
Error code f152
Just display blinkin
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
Cooktop gives EEEE error code how
search this problem on Google with MAKE,MODEL and error code EEEE
Sep 12, 2015 | Cooktops
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Mar 29, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
What do error codes E51, E52, and E53 indicate?
This link lists the error codes for your cooktop: Needapplianceparts com
Specifically, it's a "sensor break" in your front and center burners.
The solutions they recommend:
* Verify element temperature sensor is correctly connected to the generator circuit board
* Replace element if temperature sensor resistor value is not approximately 1000 ohms (blue wires) at room temperature
* Replace associated generator circuit board
Jan 12, 2014 | Electrolux 30" Electric Hybrid...
Cook top flashing code f152
replace the burner RT/FRONT
May 26, 2013 | General Electric Cooktops
GE profile JP939 flashing F152, how do I fix?
F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced. If you go to the following web page, and pick out your exact model number, you will see diagrams and parts lists that will help you get this fixed. You can order the element from that website, if you choose: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JP969 Good luck, and hope this helps.
Nov 28, 2010 | GE 36 in. Profile JP969 Electric Cooktop
F2 error after oven cleaning came across my display. I had to throw the breaker. Is this something that can be easily fixed?
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Mar 09, 2010 | Jenn-Air Cooktops
GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop Logo
20 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
