Question about Apple 24" Led Cinema Display A1267 Lcd silver
Pc adaptor...how can I connect my apple a1267 monitor to a regular pc?
How to fix the mac screen
Can you tell us more? Is the screen cracked or broken? Or is this a connect or electrical problem?
May 22, 2014 | Apple 24" Cinema Display A1267
I have a M8149 Cinema dispaly 22" and want to connect to late 2009 Mac mini. The monitor came with a strange adaptor set of ADC input to 1x each of usb, 24Pin 92x rows of 8) male ADC, and another plug...
The Apple 22" Cinema display M8149 (ADC) is one that is not compatible.
It might be better to find another brand display to work with your 2009 Mac Mini. The Apple model A1081 is DVI, but for the age (its 8 years old, the lamps are likely dimmer than new...) I would look for a resolution-compatible DVI input display (Dell Ultrasharp, etc..).
Jul 22, 2017 | Apple Computers & Internet
Ibook external monitor hardware
Check which video out connector your mac has (there have been a few in the last gew years) and then buy the appropriate adaptor from the apple store. (or ebay) This will give you a standard VGA connector that you can then connect to most monitors with a standard VGA lead.
Apr 10, 2012 | Apple iBook Mac Notebook
Dual display configuration
Have you enabled dual-head mode on the WinTerm (Start-System Setup-Dual Head)?
Mar 08, 2012 | WYSE V10LE 12G 128F512R US 90217801L...
How do I connect my apple model m7649 monitor to a dell laptop? Thanks to anyone, ron
you should be able to get hold of a convert that plugs in to your laptop then you should be able to plug the monitor in to the converter with out having any problems with display settings
hope the information is abit of help to you
Mar 04, 2009 | IBM (14R0060) Monitor
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
Screen on first start doesn't work
I have a SyncMaster 931BW which I duel Screen with a analogue montior.
There are Three things that I would check:
  1. Connection: if you are using the DVI adaptor, try using just the analogue (VGA) connection into your PC. You may have a faulty DVI adaptor which the PC cannot detect an output device.
  2. Drivers: If you have a standard monitor connect that to the PC and see if there is any output, if so, you may need to install the drivers for your monitor. You should have a Samsung Drivers Disc, or visit the Samsung website: http://www.samsung.com/uk/support/download/supportDown.do?model_nm=930BF&mType=DR&vType=L
  3. Cable: ensure that the cables are not knotted, and that within the adaptors the pins are all there and not bent as there is not a proper connection with the device.
Try them.
Jan 01, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Studio display m7649 picture will not come up when connected to toshiba laptop
I am not sure how youve manage to connect these 2 items. You did not specify whic Portage you have, but even the most recent only has SXGA video port. The Apple cinema display connector is ADC. APPLE DISPLAY CONNECTOR. No computers on the planet have this port except for apple's. It's basically a modified DVI connector. In order for you to use this monitor with your computer, you would have to purchase a DVI to ADC connector , which is another APPLE only item and selld for $100 new. You would then have to purchase a SXGA to DVI adaptor...It sounds like a costly endeavor, and with a connections your Portage's onboard video card , amynot even support the resolution for this monitor.
Hope this helps.
Oct 17, 2007 | Apple Studio Display 17" LCD Monitor
Apple 24" Led Cinema Display A1267 Lcd silver Logo
122 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
