Question about Sony DAV-SC5 System
DVD'S hang up
When playing dvds the player just stops playing and hangs up and i have to put off the system to play it again but this happens all the time.But even before it hangs up i cannot foward,pause or stop the DVD via the remote. please help.
Oops, that should nave read "solder a resistor of 820ohms between pin 203 of IC206 to the 3.3V line"
Posted on Oct 26, 2007
The (ziva-5) DVD processor IC in these units is frequently faulty. There's lots of similar complaints on message boaards all over. I had similar problems, had my unit repaired under warranty & problems returned about a year later. Eventually the DVD function stops working altogether & you can't shut even the unit down without a hard reset. Found the following tip "Solder a resistor of 820ohms between pin 203 of IC206". Reamrkably it works. If you're not game to do it yourself, get a technician to do it, cheap fix.
I have a similar problem.  After a seemingly random length of time, the counter on the display freezes and I cannot pause, stop or eject the DVD.  I can change volume, change function, etc but nothing useful.  The only way I can get the disc out it to turn the whole thing off and then back on.  Sometimes even this doesn't work first time...
I went to a Sony shop and they said I could have it looked at, but they charge £45 just to have a look!  Not sure it's worth it as I only paid a little over £200 for it.
Posted on Oct 25, 2007
Dvd player dv692h hangs after 1hr of play
Check the CD for any defect. Hold it against light and see whether there is any tiny spots. If the CD is faulty this kindl of fault can occur. OK.
Jan 09, 2012 | Televison & Video
I am having samsung dvd rw drive. when i am writing the dvd it showing successfully completed but when i am play the dvd it is hanging. i wrote dvds at 4x speed. kindly tell me the solution for this
You better start simulation before writing the dvd's in the writing softwares...
and hanging is not the problem by means of playing dvd's... try to play the same dvd's in some other system and then only you will come to a conclusion...
Sep 21, 2010 | Computers & Internet
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Jul 25, 2009 | NexxTech DP3222 DVD Player
HP dvd play on my laptop malfunctioning
grinding sounds is from the dvd drive itself. Sounds like its not sitting properly in the drive or the holder that it sits in is going bad. Either way replace the drive and that will take care of the grinding sounds. Also the more grinding sounds that happen, the more of a chance you take on your dvds getting scratches on them and going bad eventually.
Jun 11, 2009 | Compaq Presario Notebook
Hp pavilion ze2000 cd/dvd hangs
more than likely it is that you do not have the correct codecs, audio or video, to make the it play properly.
Feb 09, 2009 | HP Pavilion ze2000 Notebook
Hang up
try differt dvds memerex dvd+r
Feb 10, 2008 | Samsung DVD-VR357
Hangs/ "wrong disc display"
yea take your DVD player to a repairman your micro could be your problem.good luck.
Apr 06, 2007 | Coby TFDVD7050 Portable DVD Player with...
Sony DAV-SC5 System Logo
204 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
