Question about Rinnai Heating & Cooling
Adjusting temperature on Rinnai R53 water heater
Need to know how to make the water temperature hotter on the Rinnai R53 tankless water heater
Therinnaiguy
  • 1420 Answers
SOURCE: rinnai tankless water heater keeps beeping and showing LC
Time to flush it. LC indicates lime scale build-up.
Posted on Nov 28, 2008
cballard
  • 18 Answers
SOURCE: Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Posted on Dec 31, 2008
  • 152 Answers
SOURCE: No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Posted on Mar 25, 2009
  • 3 Answers
SOURCE: Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Posted on Jan 26, 2010
SOURCE: Exterior mounted Rinnai tankless water heater not
What is the outside temperature? If it it is below freezing, you might have a frozen pipe. Using a plumber torch heat up the pipe, if it works, replace the insulation using a heavier layer.
Posted on Apr 04, 2010
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
I have a rinnai R53 natural gas tankless water heater. we are having a very difficult time finding someone who knows how to work on these. Our problems include: having to rely on turning on one trusty...
The issue is the flow sensor, if the faucets are restricted (like showers heads) then there is not enough flow to trip the sensor. This could also be related to pipe size and water pressure.
Mar 31, 2017 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rheem water heater manual model 81x52d
Our expert will provide you reviews regarding tankless water heater. If you are planning to purchase tankless water heater tank ,you must read about Tankless water heater from here. It will help you to know about which product is best suited for you. There are lots of reviews are available for you about different products.
Rinnai Tankless Water Heater
https://tankless.review/rinnai-tankless-water-heater
Jun 03, 2012 | Rheem Water Heaters
How to change temperature setting
Link below shows step-by-step for typical tank-type gas and electric water heaters
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
If water heater used to be hotter, look at diagrams following link:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Other water heater tips and tricks:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
If you have tankless water heater, consult manual.
Changing temperature on tankless can lead to problems.
Tankless should be de-limed each year to maintain efficiency. U-tube search 'delime tankless'
Read the manual for yearly maintenance requirement.
All costs are energy, and tankless are maintenance heavy.
Mar 08, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
Dec 18, 2010 | Rinnai Digital Remote Water Heater Control...
check to see if you have a blocked line on the hot water side
Jan 08, 2010 | Rinnai Webstone The isolator EXP tankless...
Nov 28, 2009 | Rinnai Water Heaters
Need to wire a zone control for a closed system with a circulator
thats because the rinnai does not have a set up for a circulating pump it would make the unit run all the time,, they are not designed to work that way,, you will have to just wait for the hot water to get to the faucet just like before,,don't let any one tell you there is a way once the water flows it turn on the tankless so it would never shut off, you could get on that goes on a timer on say the farthest fauset away from the unit and set the timer to come on like 2 min before you are ready to use the water in that bathroom in the morning or at night other then that there is nothing else you can do
Jan 28, 2009 | Rinnai Digital Remote Water Heater Control...
Heating & Cooling Logo
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
