Question about LG Flatron Computers & Internet
How to disassemble LG Flatron L117WSB Monitor
Fix-4U
  • 293 Answers
SOURCE: how to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Posted on Dec 06, 2008
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
mjcarrasquil
SOURCE: I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
Posted on Apr 27, 2009
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
wagyp
  • 86 Answers
SOURCE: lg flatron won't turn on
have u checked the internal fuse take the back off and look for a glass fuse
Posted on Jul 26, 2009
How can disassembly LG monitor Flatron L1717S?
MONITOR CAN BE DISAMBLY BY USING SPECIAL TYPE OF SCREW DRIVERS
Jan 12, 2011 | LG L1717S-BN 17" LCD Monitor
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
My LG Flatron L1750S when powered on blinks and then goes out. I have switched over to two other machines (pc's) and the problem follows. Please help me I can afford to buy another monitor right now....
melrosebanjo, Your monitor will need to have some work done on it's "switch-mode-power-supply" and /or "INVERTER" circuit. After you view some vids at YOUTUBE that deal with replacing bad electrolytic filter capacitors and detecting poor quality intermittant solder joints. Search for vids of "LCD monitor repair" "LCD monitor disassembly" !! Learn what are the major causes of LCD BLACK screen problems. Learn the difference between BLACK AND BLANK screens. Read some of my other posts in my profile. then repost with additional comment here on fixya. also visit www.ccl-la.com/badcaps.htm. and www.lcdparts.com
www.badcaps.net FYI Good luck 12fixlouie
Dec 12, 2009 | LG Flatron L1750S 17" LCD Monitor
I want to remove the rear cover of the lg flatron w2261v monitor
simcraft's link was great ! It has pictures showing the dismantling procedure, but the document is in Chinese and so is the web site where it is located. Please remember that some internal components can retain a dangerous charge of electricity for a few minutes after disconnection from the ac outlet. Wait at least 5 minutes before attempting the disassembly. Try to find the service manual for any other LG LCD in your language and read the safety procedures - they are pretty much the same for all models.
Dec 10, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
How do I Open / disassemble LG Flatron
Remove all the screws from the screen that you can, check for screws under all soft objects and labels, after all screws are removed, use a flat screwdriver or a case opener tool to start snapping the display cover open, it is hold in place with plastic clips, these will clip open but be carefull not to break any.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
I need the elctronic layout of monitor lg flatron 775ft
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
Disassemble anlg lcd 19''
The following link will show you the 'pdf file' for the assembly of your monitor.
You should be able to reverse this procedure in order to disassemble it in order to put it back into the box.
http://us.lge.com/download/product/file/1000000449/L1951S-BN.PDF
Go to page 4 and look for "Removing the stand base" to see how to disassemble. Binary Bob
Nov 29, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
How to disassemble a LG LCD monitor
Hi...there,
Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
