Question about Yamaha DXR15 15" Active Speaker
No HF & weak LF response in a Yahama DXR-15 powered speaker
I need to find out where I can find top level / schematic drawings / diagrams for a unit on my bench as it is currently disassembled with the symptoms of dodgy HF & LF response.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
This unit has a class D switching amplifier which is complex enough to be unfixable by you unless you know what you're doing. It would seem from your diagnostic report (dodgy HF LF response) that you're not in any way a qualified bench tech and all you can do with this item is break it further. My advice - since it's still covered under warranty being that it's rather new, return it for a no cost repair at the store where you bought it.
Posted on Nov 20, 2013
I have Xavian xn125 speakers. How do I connect them in a bi-wired or bi-amp
Bi-wiring basically works wtih one amp. You need a crossover network and a signal doubler to use two amps (bi-amping). There are many diffent ways to bi-amp (horizontal, vertical,...) This link: - -http://www.soundstage.com/synergize/synergize031998.htm-- explains them all. Bi amping is usually not worth the extra price and complexity when used on smaller speakers.
May 13, 2014 | Audio Players & Recorders
Don't understand how to connect my speakers
the 4 inputs are for biamping, (using separate amplifiers for low and high frequencies). just leave the pins in place and connect the amplifier to one red(+) and one black(-) connector on the speaker. It has an internal crossover to protect the tweeter.
Nov 20, 2013 | Audio Players & Recorders
I need to remove one power amp module from an older KRK Expose E8. The obvious screws have been removed but the module still feels firmly attached to the cabinet. Is there something that I am missing?
Hello
If you have unscrewed all the seating screws of the circuit board, pull out three knobs at the rear side [HF SHELF/SYSTEM LEVEL ADJUST/HF LEVE ADJUST] and rings screwed to the switches of LF Level adjust, and the screws of XLR socket. Amp with its seating frame wcan be pulled out.
For further details log on to
www.krksys.com/krk-studio-monitor-speakers/expose.html
OK.
Apr 12, 2011 | KRK E8B EXPOSE
Problem with Mackie SRM450V2: HFsignal bleeding through LF driver,low HF OUTPUT also. Filter problem i suspect.
There is an entire crossover circuit inside that is BEFORE the amp section. There are 2 separate amps: one for HF and one for LF. Can you describe the noise you are hearing in more detail? Is hte sound effected by the gain controls at all? What happens without any input?
Thanks,
Dan
Feb 10, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
Do LF and HF +/_ both be connected and if yes do they both go to speaker system A or separate to A and B on the amplifier.
From the factory, those are equipped with "jumpers", one for red-red and one for black-black. This allows for one speaker cable to power one speaker.
The jumpers can be removed, allowing for "bi-wiring", where you run two leads from a single amp channel to both inputs on each speaker. There's also "bi-amping", using a treble amp and a bass amp dedicated to each input.
If the jumpers are missing, you can use a short piece of stripped speaker wire to reconnect the upper and lower binding posts, just be sure to match colors.clmrt5000_0.jpg
Jan 10, 2011 | KEF Audio Q55 Speaker
I have a peavey SP4XT Cabinet . the cross over network has a bi amp input for HF and LF jacks and these work for both LF HF output . Also on this network is two input quarter inch jacks for full range...
The chokes blocks high frequency, the capacitors block low frequency. You would need a digital multimeter to check for continuity. Make sure none of the resistor is burnt, which may not be obvious.
Aug 15, 2009 | Music
JRX 125 DJ SPEKER
The JRX series have weak HF drivers, only rated for some 25 watts or so. Are you running in Bi-Amp or straight? Could be bad capacitors in the crossovers. Could also be clipping of your amp, a common cause of failure is using too small an amp and pushing it past it's clean operation limits. Speakers don't like square waves. Was the "Clipping" light flashing on the amp?
Jan 06, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I need a wiring diagram for a 1994 toyota camery im puting in a new radio and it is a fuel radio i need help
Battery BLUE/YELLOW (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna BLACK/RED (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Amp Location BEHIND GLOVEBOX
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Jan 04, 2009 | 1993 Toyota Camry V6
Need to install new radio
This should Help:)
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Oct 25, 2008 | 1991 Honda Accord
Bi amp
Hi there, I am assuming that you wish to BiWire the speakers. This involves removing the link on the back of the speaker box and running additional speaker leads for the HF drivers, as well as cable for the LF drivers. BiWiring allows you to use different cable that has been designed with high frequency signal path in mind. It may feature things like silver plating, low capacitance, or as many other "features" as can be tagged to the cable to sell it as a specialist HF conductor. The benefits may be subtle, and not be that noticeable. It does isolate the potential voltage drop along the length of the cable associated with LF energy away from the HF side of the speaker system, and take advantage of Skin Effect, where HF energy tends to travel on the surface of the conductor.
Using a single cable for each channel and leaving the links fitted is perfectly fine and will operate no worries. You could go and spend the extra cash and upgrade your cables to HF and LF BiWire.... the sky is the limit on cost here for what may not be a noticeable difference:)
BiAmping in a different story where much more performance increase is achieved by using a separate channel to amplify HF and LF signals. But you need an amp that has a built HF and LF outputs for each channel to do this. They exists but I have not seen any surround amps that have it.
Go with decent quality realistically priced speaker cable first, then add your HF BiWire to the rig if you are looking for that little bit extra from it:) Good luck, and happy listening.
regards
Graeme
Feb 28, 2008 | Monitor Audio Bronze B4 Speaker
Yamaha DXR15 15" Active Speaker Logo
61 people viewed this question
Top Yamaha Car Audio & Video Experts
xxxxxx xxx
Are you a Yamaha Car Audio and Video Expert? Answer questions, earn points and help others
