Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Keys will not open or lock the powerbolt - Weiser Lock POWERBOLT ELEC DEADBOLT
When I push lock key it opens,when I push code keys It locks
Your lock is set for the opposite 'hand' of the door. The PowerBolt lock has a jumper that changes this. Signature series are supposed to set automatically during installation. Check the instructions.
Aug 31, 2014 | Kwikset Locks & Locksmithing
How to key in code
This link will take you to the installation & programming instructions (on page 6) for the Kwikset Powerbolt, which is exactly the same as the Weiser Powerbolt:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Jul 31, 2011 | Weiser Lock GED1460X GED1460X15A Antique...
Original key that came with lock won't open lock.
Your best bet is to contact Weiser Lock directly. Here is a link to the contact information that you need:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Feb 18, 2011 | Weiser Lock GED1460X GED1460X15A Antique...
I have a new key sylinder for my combination lock how do i reset it so i can lock it with the key
I hope this helps you, for your type of lock:
http://www.weiserlock.com/Support/Faq/50160000000HhlbAAC.aspx
Reinstallation begins with step 5.
If not, try researching the Frequently asked Questions link on the same page. Good luck!
Feb 11, 2011 | Weiser Lock GED1460X GED1460X11P Venetian...
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Powerbolt 1000 does not accept code,remains locked,key inside room and not obtainable
you are too slow, i called a locksmith. h drilled out te key entry and openedthe lock. then he replaced the key entry with a new one. i was hping that you might hav known the master code. thanks anyway. please note that i will not accept any charge for your involvement in this affair.thanks again, isadore
Sep 04, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
