Question about Kinivo Bth220 Bluetooth Stereo Headphone - Supports Wireless Music
I want to reset my Kinivo BTH 220, how to do that ?
I used to connect my BTH 220 with my laptop and mobile but something happened now. I have a problem connecting BTH 220 to my mobile. It is pairing and connecting with my Laptop's Bluetooth but it is not connecting with my mobile. I want to reset and try connecting it to my mobile. Please somebody suggest me how to solve this problem/ reset my BTH 220.
Why does my kinivo bth220 headphones have a flashing red light on them no matter how long i charge them and they will not turn on
The batteries won't charge. You might want to google around for replacement batteries.
First I'd try a factory reset. PRess the +, - and multifunction button for 6 seconds until the blue light flashes and it shuts off. When you turn them on next, it's in pairing mode and try again.
Aug 10, 2014 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Ineeda free driver for kinivo
Go to kinivo.com,click support,click downloads,under audio info on how to pair with computer and user manuals.No mention of drivers but you can search on web for bluetooth drivers for the windows version you have.
Nov 05, 2012 | Kinivo BTH220 Bluetooth Stereo Headphone -...
Why wont kinivo bth220 wont link with my phone no matter what i try
Can you confirm if you are able to put the BTH220 headphones in pairing mode. Please try the following steps and see if works:
  1. Make sure that the headphones are fully charged.
  2. Switch off the headphones.
  3. Put the headphones in pairing mode by pressing the MFB button (center) for 7-10 secs till you see the red and blue LED blinking alternatively. Please do not leave the button as soon as blue LED appears.
  4. Follow the operating instruction of your Bluetooth device to start the pairing process.
Sep 29, 2012 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Driver problem
U have to install Active sync provided in the softeare cd by asus or u can download active sync 4.5 from net and then u shall be able to connect
May 27, 2009 | ASUS Mypal A730W Windows Mobile 2003
Driver problem
just download active sync if you are using windows xp
mobile device center if you are using Vista or windows 7
May 23, 2009 | ASUS Mypal A730W Windows Mobile 2003
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Mar 05, 2009 | Acer Aspire 5610-4648 Notebook
Want software for internet.
Hi. ur mobile is compatable for internet u can access wap sites on mobile but if u want to connect mobile with pc then u can connect with Blue tooth . ur mobile is having inbuilt BTH but for computer u need 2 buy BTH and u need the install BTH software on PC(software will come along with BTH)  then u can also access internet on PC.
Gizmo1
Oct 09, 2007 | LG KG800 Cellular Phone
Open Questions:
Kinivo BTH220 Charging Issue I have recently purchased the Kinivo BTH220 bluetooth headphones, they were seemingly shipped fully charged and worked beautifully while charged. I read the user manual before I even touched the headphones and followed the recommendation to fully use the battery. After doing so I tried to charge the headphones. In the included user manual there is a section called "Charging the Battery:". It states that when the headphones are charging a red light will appear, and when finished it will turn off. I plugged them in, so far satisfied with the product, and only seconds later the red light shut off. I tried to turn them on and the alternating blue and red flashing lights began, I assume that means the battery is too low to turn on. Since that point I've been trying varied different sources to charge my headphones. Wall chargers, car chargers, the usb port on my laptop, but none have succeeded on turning on the red light for more than ten seconds. I used a different usb cord to see if it would resolve the issue, and so far I can only manage to get it to charge for moments. I've tried plugging it in partially and such, but that hasn't worked either. Is there something in the user manual I have missed? Is it an issue in manufacturing? I did buy it over Amazon but the provider had great reviews and the product came unopened with no signs that it had ever been, even came in a vacuum sealed thin plastic covering. Is this a common issue, or are there no known solutions?
Apr 17, 2013 | Kinivo Bth220 Bluetooth Stereo Headphone -...
See all Kinivo Bth220 Bluetooth Stereo Headphone - Questions
Kinivo Bth220 Bluetooth Stereo Headphone - Supports Wireless Music Logo
67 people viewed this question
Top Kinivo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kinivo Audio Player and Recorder Expert? Answer questions, earn points and help others
