Philips SHD8900/79 headphones power s/w won't work
Slide s/w to turn on/off on right earpiece just slides back and forwards, but does not activate the s/w. Had been using & had problem turning off. How do I get the earpiece apart to reconnect the slide with the switch?
    Top Expert:
  • Computers & ... Master
  • 23,154 Answers
I thought the ear piece was sealed.
Posted on Nov 19, 2013
4 Suggested Answers
mycomputertu
  • 35 Answers
SOURCE: my hp wireless switch is not working
Try opening up your Device manager and see if there is an exclamation mark next to the Wireless Network Controller. If there is try re-installing the driver. If that doesn't work go to your computers support site and try finding an updated driver there for your wireless driver.
Posted on Jul 08, 2009
technolust
  • 340 Answers
SOURCE: I have an hp mini and the power switch on the side
Hi There,
It sounds like you've broken the post that acts as a snap action switch to turn on your laptop. With that post broken, you will still physically be able to move the switch back and forth, however the snap action will not work and your laptop will remain off.
You can fix it yourself, it's not terribly ******* a netbook but for someone without experience it can be confusing, here is a link to a disassembly video: http://www.google.ca/url?sa=t&rct=j&q=hp%20mini%20disassembly&source=web&cd=2&sqi=2&ved=0CFsQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dq2xQUT9NbIg&ei=B6XPT47GG7Ky0QH0pumkCA&usg=AFQjCNFdTsIR3hOFdu_OfA_b3sAHpYbXxQ
A repair shop should be able to fix this issue for you in under ten minutes and under $40.
Posted on Jun 06, 2012
SOURCE: HP Mini 110-1012NR PC power
I had the same problem just now, but didn't want to open up my pc. I took a pin and cleared the dust away around the switch; took a few tries but eventually managed to shift whatever had been making it stick.
Posted on May 31, 2013
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
On my kadak 4400 I placed a slide tray with 35mm slides in. After turning the power on I attempted to advance the first slide. Nothing happened with the slide. I turned it off reset the tray and tried. ...
Try turning your projector on without a slide tray. Cycle it 2 or 3 cycles in reverse. Place the tray back on the projector and cycle forward. By cycling it a few times in reverse, it re-sets the cycling mechanism.
May 08, 2012 | Kodak Carousel 4400 Slide Projector
Drivers seat 2000 outback
So here is a diagram of the seat circuitry for your car. Since every other function works except the forward/backward slide function, that leaves basically the forward/backward slide motor, the seat switch, and/or the wiring. If you can verify that the wiring under the seat is in good condition without obstructions, chaffed wires, and/or wires pulled too tight, then it's safe to say it's down to just the motor and/or the switch. Sometimes if the passengers front seat has the same switch, you can plug it in to the drivers' side connector and see what works and what doesn't. If the seat works fine with the other switch, then that's all it needs, if not then it will need a motor. If the other seat doesn't have a switch then you can find them at wrecking yards, or just supply power and ground to the motor in question to see if it works. If it does, then you know you kneed a switch and if not then a motor.
I hope this info helps!~subyguru~
82066173
Nov 14, 2011 | 2000 Subaru Outback
My philips SHE9550 ear phones' right end has stopped giving sound output all of a sudden. Left one is fine. Please suggest some solution to rectify this. Is it possible first of all to resolve this or...
It depends on if the fault is on the wire due to a break or snap or if the fault is in the earphone pin. Now both of the above faults can be rectified as the wire can be joined and the pin can be replaced.
Now if the fault is within the earpiece then it must be checked if the unit is faulty- a open coil - or a wire break to the unit.
Now in all the above cases a multimeter must be used to check the continuity from the headphone pin to the earpiece. An open wire can be rectified by replacing the wire, if the earpiece unit is faulty you need to replace.
Jul 28, 2011 | Philips SHE 9550 schwarz Headphones
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
How do I slide the green toner tabs?
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover (it is the full length of the cartridge holder).
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
Broken power seat - cannot slide backward. Can I slide it manually?
Ck for debri or other objwcts in way of tracks Does it try to move? If so, there is an obstruction, If not trying or no sound when switch is moved, could very well be a fuse or the forward limit switch is being affected by excess forward travel. Move the switch yo back and without kinda help it. if it's trying.
May 17, 2009 | 1992 Toyota Camry V6
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Bluetooth
what do i have to do to fix this bluetooth problem? it works before why suddenly it just won't activate
Apr 07, 2008 | Samsung X820 Cellular Phone
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
