Question about Irons
Sharper Image Manual for GM400 - Irons
Sharper image isplash sr 286 manual
this is due to some software problam or you should check your setting of pairing proparly
Jan 16, 2014 | Irons
How to clean SI 588
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Jan 05, 2014 | Sharper Image Irons
Sharper image humidifer ev-hd10
follow this steps and fix it. God bless you
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 28, 2013 | Irons
Need instructions and codes to program Sharper Image Jumbo Remote
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals.
I hope that helps.
Mar 22, 2010 | Sharper Image TI150 Iron
We have a TI150 wrinkle free steamer, and we need the water reservoir cap. Can anyone help us locate one, thank you.
It was very easy to fix the problem. We just substituted a wine cork for the plastic top and it works great. It did not take a brain surgeon or a group of people to help us. Just good ole American ingenuity.
Jun 10, 2009 | Sharper Image TI150 Iron
I can't figure out how to attach the accessories
Pray, this was the clencher! No, you do not remove the piece already attached. The attachments to snap on but it takes help from above. Truly.
Nov 29, 2008 | Sharper Image TI150 Iron
Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Jan 15, 2008 | Euro-Pro G6118 Iron
Irons Logo
63 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
