Question about Xerox Phaser 6180N Laser Printer
Color printer toner not adhering to paper and there are horizontal lines printing as well.
My phaser 6180 color printer toner is not adhering to paper and I just noticed that there are horizontal lines on the paper as well.
    New Friend:
    Problem Solver:
  • 8 Answers
There are three causes of toner not sticking (fusing) to the paper.
1. Poor quality remanufactured or 'compatible' toner cartridges, that don't have the correct toner in them. Laser printer toner, especially for colour laser printers , needs to be formulated for THAT particular printer 'engine'. All toner is NOT the same. A GOOD quality remanufactured cartridge that DOES have the right toner will be fine.
2. Faulty fuser. Particularly if the fusing is patchy. This is usually the fuser heat lamp that is starting to fail (will often blacken in patches on the lamp surface - not visible as this is inside the fuser pressure roller. A replacement fuser will fix this.
3. Too thick, or damp media If you are printing on card, and have not 'told' the printer that it is using something thicker than 80 gsm paper, the heat from the fuser just doesn't get through the media and heat the toner enough to fuse it. Setting the media type (in the printer driver) correctly will sort this out. If your media is damp, the moisture content will prevent the toner fusing. Ensure the paper is NOT damp or excessively cold.
Posted on May 01, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
HI COULD BE YOUR PRINT CARRIDGE
Posted on Nov 19, 2013
5 Suggested Answers
SOURCE: Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Posted on Mar 03, 2009
  • 49 Answers
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Posted on Mar 30, 2009
StevenC82
  • 160 Answers
SOURCE: Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Posted on Dec 19, 2011
  • 18 Answers
SOURCE: Xerox Phaser 6180 keeps saying load papertray with
When you adjust the length guides there are 3 little white switch actuators that eith do or do not actuate three little white switches inside the machine which tell the machine the position of the length guide.
For 11"paper only the bottom one should be sticking out to actuate the bottom switch inside the machine.
Make sure they are intact and that no torn off piece of paper is holding a switch actuate.
If you rmove the tray with a flashlight you can see the three switches inside the machine on the right about 2/3rds of the way back.
They should move freely but they do not go click when you press on them
I don't see anything that monitors the width of the paper in the tray..
If all that works, time to call service.
Posted on Aug 20, 2012
Phaser 6180 streaking
If it's just one colour, it's usually THAT colour Toner cartridge that's the cause .
Jun 23, 2014 | Xerox Phaser 6180N Laser Printer
Clean printheads on Xerox phaser 6180
This type of print quality defect shows up if you have loaded the wrong type of paper in your machine and didn't remember to change the paper type (plain paper, card stock, labels, etc.).
This can also happen if the paper has a high moisture content, or if the humidity in the room is too much. Also make sure the room temperature is within its normal operating range (not too hot, not too cold).
The problem you describe could also be caused by using non-Xerox toner/drum units. Compatible toners don't work very well in Xerox printers.
Aside from those problems, the only other thing would be if the Fuser Assembly is near the end of its life...it will also cause some print quality problems like you are describing.
Dec 24, 2013 | Xerox Phaser Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Fuzzy horizontal lines printing every 1 1/8"
Sounds like you've already diagnosed the problem.
Oct 11, 2012 | Tektronix PHASER 6180 All-In-One Laser...
Xerox phaser 6180. Printing 3 blue horizontal lines spaced evenly apart on printed page. New toners. Could it be fuser? transfer roller?
Just because they are new toners, doesn't mean they can't be faulty.
Faults that show in just a single colour are almost always related to THAT colour toner cartridge.
TRY THIS
If you still have your old cyan toner, swap the chip from your new toner and put the old toner in the printer, then test.
If the lines are gone, it's the NEW cyan toner cartridge.
Jan 07, 2011 | Office Equipment & Supplies
Dell 3110cn Color Laser Printer Certain colors will not adhere to the page when printed on heavy paper. Combination of green/black wipes off the paper when rubbed.
Either the paper is just too thick for the printer to fuse the toner correctly, or you've NOT selected the right paper type (in the printer driver options.
If you're just printing that same as you would on ordinary A4 paper, the fuser can't get enough heat through the thick paper to fuse the toner.
May be a wrong toner problem if you've done this successfully before, but only had this problem since changing toner cartridge(s)
Oct 19, 2009 | Dell 3110cn Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Niallbt
Mar 27, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 6180N Laser Printer Logo
113 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
