Question about Electrical Supplies
Kubota z600 head bolt torque and pattern
Please help,no manual on board.Is torque around 50 ft lbs...thank you
heavy389
SOURCE: head bolts torque and sequence
They are listed in all Chilton Repair books,available at any auto store
Posted on Nov 30, 2008
  • 3567 Answers
SOURCE: torque specs for cam on 2006 honda crf250r
Rock the caps around to make sure the bearing locating clips are lined up. Torque the bearing caps to 12 foot-pounds. At this point you must check the valve clearances again. If any are off, the cam must be removed and the correct shims installed.
Please rate this solution. Thanks!
Posted on Apr 07, 2009
SOURCE: 3 cylinder kubota , head bolt torque specs
I have similar problem, trying to find the tappet clearance for engine D850. Try pasting this link in, might help ya some. http://www.tractorsmart.com/KubotaEngineSpecs/Kubotadieselengineoverhaulspecifications.htm
Posted on Jun 07, 2009
stevenhurc
  • 450 Answers
SOURCE: torque specifications cylinders head bolts
for 1.5/1.6L DOHC, 18 Ft-lbs + 70deg + 70deg + 50deg
for 1.8/2.0L DOHC, 18Ft-lbs +90deg + 90deg +90deg
Posted on Jun 24, 2009
GeoffW1
  • 3961 Answers
SOURCE: i need how much torque the head bolts for toyota camry 1996
It is 36 ft-lb, but done in two stages to a prescribed sequence.The bolts should be oiled. See here p67
http://www.turboninjas.com/camry/eg1.pdf
This is for the 4-cyl. The V6 is 40 ft-lb, and the link is .....eg2.pdf.
Posted on Aug 13, 2012
Can you please give me the torque settings for the Ford bantam rohcam 1300 cylinder head bolts thanks
65-70 ft/lbs - see sequence below.
do it in 3 stages: 25 ft/lbs, then to 50. Wait 15 mins then do final tightening : 65-70 ft/lbs. Work your way from the middle bolts toward the outside in a opposing cross hatch pattern - see below for the sequence. This applies to unbolting the head (in reverse: ie work from 10 down to 1):
9 3 1 5 7
8 6 2 4 10
Hope this helps
Oct 18, 2014 | Cars & Trucks
Torque setting engine
For a 1997 3.0L they are torqued to 8o Fl/lbs. in three steps. First to 25, then to 50 then to 85 and make sure you follow the proper tightening pattern so the heads are tightened down evenly. You will also need a 10mm Allan hex to remove/install them.
Aug 01, 2014 | Plymouth Grand Voyager Cars & Trucks
Hi we are rebuilding a ford 4600. Can anyone tell me the torque settings for the bigend, main and head bolts please? Any help would be great, Thanks bb
On the head, first tighten the bolts following the sequence to 40-50 ft-lbs, run through the sequence again and tighten to 70-80 ft-lbs, and again at 95-105 ft-lbs. The intake valve clearance to .017; exhaust is .021. Connecting rods torque 60-65 ft-lbs. Main caps torque to 115-125 ft-lbs.
Randy - TMS Stoller Tractor
Jul 05, 2011 | Ford Tractor Grill 2600 3600 4600 5600...
Torque the cylinder head bolts for mitsubishi lancer 2002
Try this
I dont know which engine you have.
420a
1. Torque all center bolts to 25 ft-lbs, torque the 4 corner bolts to 25 ft-lbs
2. Torque all center bolts to 50 ft-lbs, torque the 4 corner bolts to 50 ft-lbs
3. Re-Torque all center bolts to 50 ft-lbs, re-torque the 4 corner bolts to 50 ft-lbs
4. Tighten all bolts in the sequence from #1-#10 an additional 1/4 turn.
7-Bolt 4G63
1. Torque all bolt to 58 ft-lbs in order
2. Loosen all bolts completely to 0 ft-lbs
3. Torque all bolts to 15 ft-lbs in order
4. Tighten all bolt 1/4 turn in order
5. Tighten all bolts an additional 1/4 turn in order.
ARP Head Studs
1. Tighten all bolts to 40 ft-lbs
2. Tighten in steps of 10 ft-lbs increments until the specified torque that you are looking for is reached. This can vary with the amount of boost you plan on running.
Jun 30, 2011 | 2002 Mitsubishi Lancer
Can you tell me the torque spec.on head bolts for a 1985 ltd 3.8 thank you
Six IN LINE - 6L
Fig.: Cylinder head torque sequence - 6 -cylinder engine
Cylinder head torquing should proceed in three steps and in the prescribed order. Tighten them first to 50-55 ft. lbs. (65-71 Nm), then give them a second tightening to 60-65 ft. lbs. (78-84 Nm). The final step is to 70-75 ft. lbs. (91-97 Nm), at which they should remain undisturbed.
Six IN V - 6V
Fig.: Cylinder head bolt torque sequence - 6 -cylinder engine
Tighten the head, according to the illustrated sequence in three progressive steps. Tighten the bolts to 50-55 ft. lbs. (68-74 Nm), then 60-65 ft. lbs. (81-88 Nm) and finally to 75 ft. lbs. (102 Nm).
Hope this helps (remember to rate and commene this answer).
Jan 19, 2011 | 1985 Ford LTD
Looking for head bolt troque spec for 3.4l impala sfi04
Please don't forget to rate. Thank you:
Left side front cylinder head
Cylinder head bolt torque sequence-3.4L engine
  • Cylinder head by aligning it with the dowel pins
  • New cylinder head bolts coated with a sealant (such as GM 1052080). Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm). Using a torque angle meter turn the bolts 90 degrees in the proper sequence.
  • Left side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plugs. Torque the plugs 11 ft. lbs. (15 Nm).
  • Right side rear cylinder head:
  • New cylinder head gasket
  • Cylinder head on top of the gasket and make certain it is lined up properly with the dowel pins
  • Right side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plug wires
  • Exhaust crossover pipe. Torque the fastener to 18 ft. lbs. (25 Nm).
  • Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10 Nm). Using a torque angle meter torque the fastener an additional 30 degrees.
  • Lower intake manifold. Torque the bolts to 115 inch lbs. (13 Nm).
  • Upper intake manifold. Torque the bolts to 18 ft. lbs. (25 Nm).
  • Nov 26, 2010 | 2004 Chevrolet Impala
    I'm looking for the Head Bolt torque specs for a 2005 dodge stratus 2.7L
    STEP 1 TORQUE BOLTS 1 - 8 - 35 FT LBS STEP 2 TORQUE BOLTS 1 - 8 - 50 FT LBS STEP 3 TORQUE BOLTS 1 - 8 -50 FT LBS STEP 4 TORQUE BOLTS 1 - 8 - PLUS 1/4 TURN STEP 5 TORQUE BOLTS 9 - 11 21 FT LBS.
    Sep 02, 2010 | Dodge Stratus Cars & Trucks
    Head gasket torque specifications and sequense
    Cylinder head bolt torque sequence—3.4L engine
  • Spark plug wires
  • Mar 06, 2010 | 2001 Chevrolet Venture
    Need to the torque specs for a 1999 Dodge Durango
    Head Torque sequence Step 1: torque to 50 Ft/Lbs Step 2: torque to 105 Ft/Lbs recheck final torque in sequence.
    Torque intake manifold: Step 1: 12 inch/Lbs, (hand tight) Step 2: 72 inch/Lbs, (6) Ft/Lbs Step 3: 12 Ft/Lbs
    torque intake plenum: Step 1: 24 inch/lb (hand tight) Step 2: 48 inch/lb (4) Ft/Lbs Step 3: 84 inch/lb (7) Ft/Lbs (To torque bolts, start in center using crisscross pattern)
    Apr 07, 2009 | 1999 Dodge Durango
    Need torque specs
    General spec is 8 ft lbs. 16 ft lbs then 90 deg turn. the pattern is the key. follow the pattern in the manual
    Apr 07, 2009 | 2000 Harley Davidson FXSTS Springer...
    Electrical Supplies Logo
    70 people viewed this question
    Top Electrical Supplies Experts
    ken skalski
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
