Question about ZTE Adamant - Black verizon Cell Phone F450 Qwerty
Verizon Adamant turns on and off when i attempt to charge
When I plug my phone in the to the charger, it just turns on and off repeatedly. Tried removing the battery, didn't help.
2 Suggested Answers
mobil master
  • 14641 Answers
SOURCE: wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Sep 16, 2012
Moto g wont turn on
Try holding down the power key for 30 seconds. You should see a white indicator light blink. If not then plug it into a charger that you know works. If your not using the original charger it may not be getting enough power. You may need to charge it for a couple of hours and then attempt to turn it on while on the charger by holding down the power button for atleast 30 secs or untill it turns on.
Sep 20, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
My verizon adamant phone is stuck on "updating software... Please do not unplug USB cable"
Same thing happened to me. Believe it or not, my verizon rep said that "sometimes phones just glitch beyond return". I had to get a new phone all of my pics, contacts, etc lost. It would be one thing if this happened because I dropped the phone or it was physically damaged, but it completely ruins the unit all because I followed the directions when updating the software. Wtf would that be programmed into the phone??????
Apr 21, 2014 | ZTE Adamant - Black verizon Cell Phone...
When i charge my verizon adamant it says charge complete but it is not
May be you can go to stores and try with batterries and charger to make sure where the problem actually lies.
Feb 16, 2013 | ZTE Adamant - Black verizon Cell Phone...
I charged my adamant zte and now it won't turn on
Hello Dear:::::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 18, 2013 | ZTE Adamant - Black verizon Cell Phone...
Samsung brightside will not turn on.
If the phone lights up when you plug in the charger it is probably the ribbon cable that flexes every time you open the keyboard. About 25 bucks from cellphonerepairshop.com. Be sure to flip up the little latches on the flex cable ends before attempting to plug or unplug the cable ends.
May 26, 2012 | Samsung Verizon Brightside Sch-u380 Black...
My phone won't charge or turn on. I plugged it into the usb drive, and it tried to sync to the computer, and i remembered i have to turn it off before it would charge and not try to sync to the computer. I...
try to get a new charger or battery if that does not work then i suggest a new battery....... of there is no luck then ask the verizon people... if they tell you to get a new phone then throw a fit and that (most of the time) works :)_
Dec 24, 2009 | LG enV3 VX9200 Cell Phone
I have the Verizon EnV2, & it won't charge. Is it my battery?
sounds like you have a short between the chrager and the phone... look and see if anything is bent where the phone and charger meet....if not.. call verzon your phone my still be under warranty and if it is they have to send you a new one ....of its just the charger they will GIVE you a new charger too
hopes this helps
Dec 09, 2009 | Verizon Communications enV2 Cellular Phone
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
Dec 01, 2009 | Verizon Communications Motorola V325i...
The Blink Of Death!
well, the cause is definately a software issue...what caused it is hard to say. could be physical or moisture damage, but if u are certain that is not the issue, the phone can be replaced under the warranty if u have had it less than a year, or if u have the extended warranty. if it is damaged or out of warranty, you can use ur insurance, if you have it.
Jul 04, 2008 | LG enV VX9900 Cellular Phone
ZTE Adamant - Black verizon Cell Phone F450 Qwerty Logo
42 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
