Question about Hardware & Accessories
Can woods timer model no.ES-A263US1 manual
Can not set the timer on the 300w tungsten
SOURCE: Woods In-wall Timer Heavy Duty, Model #59018 -- I
Quick answer:
1) Programming steps say 'press clock key to return to current time and day'
2) Use mode button and change between AUTO & RND >> try manual override in each mode
3) Does timer turn lights on-and-off with program, or do they blink too?
4) Swap Black and Red wires
5) Try timer on light in different room, on different circuit breaker
6) Timer might be defective
Longer answer:
Woods 59018 manual does not show troubleshooting steps except 'check wiring; switch Red and Black leads; and/or reset programming'
Seems unlikely you could program timer unless timer is wired correctly ... unless there is a short of some kind.
To review wiring.
Green goes to bare ground wire.
White goes to Neutral white wire (neutral is usually 2 or 3 white wires twisted together and shoved to back of box)
Black must connect to Hot from circuit breaker
Red must connect to Load (light, fan, motor etc)
How to test wiring
Disconnect timer and set aside.
Mark each wire
Separate wires in box so they don't touch
Use ordinary tester (you can tape tester leads to wood sticks)
Turn on power
You should have two black wires that were originally connected to switch
Test black wires to bare ground > when tester lights up, that is the Hot wire.
The other black wire goes to Load
Now you want to find the neutral.
Test the Hot black wire to white wires in box.
When tester lights up, that is neutral.
If everything checks out, I guess timer is defective.
Posted on Sep 29, 2010
SOURCE: Need Manual
http://waterheatertimer.org/Woods-timers-and-manuals.html
Manual for Woods 59337
http://waterheatertimer.org/pdf/Woods-59377.pdf
Posted on Nov 23, 2010
jyackle5
  • 8197 Answers
SOURCE: How do I set my
You can get the manual on the link below.
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
Posted on Jan 23, 2011
SOURCE: i just bought a woods timer model rand 1400 (
Just got Woods Model RAND1400 (49750) "Indoor Random Timer" from Menards. It seems to be preset to a "random" pattern of on/off times throughout a week. The instructions (essentially) say to set the day/time by turning the front dial (segmented into 7 days, day/night for each day, and a couple hour marks for each day/night). The instructions for my timer list on/off times that are different for each day, and with different durations. It seems to generally turn on/off during dark hours. A manual override switch turns power "on." Plug the timer into the wall, plug the lamp into the timer. That's it. Not very precise, but probably shouldn't be either. I got three of these things, planning to set each to a different day so they don't all turn on/off near the same time as each other. Phone number to call for further assistance: 1-800-561-4321 (M-F, 8:30am-5:00pm, Eastern time).
Max load: 15A, 1875W Resistive, or 8A, 1000W Tungsten. 125 VAC/60Hz,
3/4 HP, 8A Ballast (fluorescent)
Cat: # TM261A
Hope that helps.
Posted on Mar 06, 2011
SOURCE: I bought timer model #402A.
1250 watt tungsten: Tungsten is the tungsten filament in light bulb.
So 402A timer is rated for light bulb only and not dehumidifier motor load.
1800 watt dehumidifier will burn 402A timer, and could start a fire.
I suggest Intermatic heavy-duty appliance timer HB113C:
http://waterheatertimer.org/pdf/070-appliance-timers.pdf
http://www.smarthome.com/25071/Intermatic-HB113C-120V-20A-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Posted on Jun 25, 2011
Can not find the instruction manual for my III Woods #50016 outdoor timer. I do not know if it is similar to any of the other Woods timers that you've already answered questions for.
Here is the manual Janet
[PDF]Timer Instructions in English https://www.muni.org/Departments/health/.../timer%20instructions2012%206.pdf
  1. Cached
  2. Similar
Woods 50016 digital timer for use with engine block heaters. Refer also to enclosed directions for additional safety cautions and Spanish and French translations. Set timer to supply electricity to your vehicle's engine block heater 2 to 3 hours ...
[PDF]Woods 50016 timer manual - Water Heater Timer
waterheatertimer.org/pdf/Woods-50016_Instruction-manual.pdf
  1. Cached
  2. Similar
Page 1. http://waterheatertimer.org/Woods-timers-and-manuals.html#50016.
Woods 50016 Digital Timer for Engine Block Heater: Amazon.ca ...
https://www.amazon.ca/Woods-50016-Digital-Engine-Heater/dp/B006LYHG4W
  1. Cached
Rating: 2.2 - ‎8 reviews Set timer to supply electricity to your vehicle, s engine block heater 2 to 3 hours before ... Woods 50016 Outdoor Digital Block Heater Timer, 24-Hour. ... rating: 15A, 1875-Watt; tungsten rating: 10A, 1250-Watt 8A ballast; controls up to 1/2 HP. .... This causes it to go into a setup phase and not provide power to my block heater.
Nov 15, 2016 | Woods Hardware & Accessories
We have an older Malibu 300w low voltage transformer that has a non-working timer and want to install a photo eye on it. The instructions for the photo eye as well as recent IFU from Malibu show 3...
How about this solution:
Don't use the photo eye from Intermatic, since unsure if older timers might not be made for that feature.
Instead, plug power pack into photo-eye timer.
Or plug power pack into ordinary wall timer:
Copy following links for resources:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Call Intermatic and they might have solution for photo eye.
Gene
hh
Oct 06, 2013 | Intermatic Malibu 300W Power Pack...
HOW TO USE THE TUNGSTEN E-023 timer clock
1) Tungsten is not a brand, and probably means tungsten light bulbs or filament-type incandescent light bulb.
2) Copy following link:
http://waterheatertimer.org/How-to-set-timers.html
3) Add comment and include photo of timer or describe timer in detail
Dec 02, 2012 | Hardware & Accessories
I installed a digital timer GE 15086. Does it work with fluorescent lights?
15086 manual says 15A Tungsten.
Tungsten is incandescent.
manuals usually say CFL or fluorescent if they are made for those loads.
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Honeywell (500 watt/40 watt minimum) Aube T-1032 handles fluorescent and halogen
http://waterheatertimer.org/Aube-timers.html
Woods 59028 works with CFL
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | General Electric Hardware & Accessories
I just bought a woods timer model rand 1400 ( 49750) .\r\nI dont have manual can i set that for 18 hrs on 6 off . and how do i set it.
I answer questions for free
I specialize in timers
You can add a comment and I will answer
My files do not show a 49750
The Woods product site does not show a 49750
A web search for Woods 49750 shows no product
Below is a photo of the Woods manuals that I have. These manuals are for the programmable timers.
Are you sure you have the correct product number?
Add a comment so we can get your question answered.
I post the manuals for free.
Nov 01, 2010 | Hardware & Accessories
So far, I bought 5 Woods 59377 Indor Digital 7-day timer and each of them stopped working. The timer is connected to the hologean 90 Watt lightbulbs. What's causing the timer to stop working?
Check following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
1) Manual shows 59377 timer is for Tungsten (incandescent)
2) GE faq page shows halogen and incandescent together, so the timer may be rated for halogen. It is unclear.
http://www.gelighting.com/na/home_lighting/ask_us/faq_compact.htm
3) Buy cheap circuit analyzer at home center and check circuit. Whenever electronic timers fail, circuit is suspect. The light fixture may be causing interference. Try timer on different circuit. Try timer on different load.
4) Use mechanical timer instead of digital timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Jul 28, 2010 | Woods Industries 59377 Indoor Digital...
Hardware & Accessories Logo
208 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
