Question about Whirlpool Refrigerators
ET8CHMXKT0 WATER LEAKS INTO BOTTOM OF FRIG
Maytag317
  • 1136 Answers
SOURCE: The freezer leaks water onto the bottom of frig
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside freezer panel and remove the ice covering the drain hole. Once the drain hole is clear, flush it out with hot water to make sure it is open. I use a baisting syreinge to flush them. Sometimes the dust from under the refrigerator gets in the drain and plugs them. I have also seen the drain tube under the refrigerator hanging down to low and blocked off where it goes into the drain pan.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 23, 2009
  • 363 Answers
SOURCE: inside of frig sweats so much water collecets
sounds like you need to clean all of the door seals and all contact points on the refrigerator. Do not use alcohol. use a damp rag
Posted on Jul 30, 2009
arikrom
  • 528 Answers
SOURCE: water leaks inside,cant seem to locate drain
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Posted on Jan 02, 2010
SOURCE: Water leaking. Mongram zic[s]360 (frig on top,
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Posted on Jan 24, 2010
heatman101
  • 43501 Answers
SOURCE: side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
Why is there water dripping from the bottom of the water/ice dispenser
The solenoid valve that controls the water dispenser is leaking internally. It will be a double valve (one for ice, the other for chilled water) located at the bottom of the frame in the back of the unit. To find it, just trace where the plastic tubes originate from.
Easy to replace.
These leaks are sometimes caused by particles getting trapped on the valve seat. This can be prevented by use of an inline water filter on the copper supply line.
Oct 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Side by side frig/freezer. Freezer auto defrost
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water running under frig.
have you tried turning the water off(if you have a tap/faucet behind unit).....
Feb 14, 2010 | Sub-Zero 650 / O Bottom Freezer...
2 times in a period of 24 hrs it leaks water out the bottom of refri
Might should check for water leak in the main line that runs at the bottom of the frig behind the grill in front. If not there check all lines in back and the water solenoid sometimes it will have a hairline crack that will cause this. BB
Dec 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaks from under the middle but not all the time maybe once or twice per month
condensation normally drains thru a tube at the bottom of the frig to a drip pan under the condenser coil (under the frig) .. the water normally just evaporates from the pan .. if there is too much moisture in the frig, that usually means a door is ajar (not closing completely) or the seal on the door is not sealing properly .. warm moist air from the room getting in will cause too much condensation .. the drip pan may overflow ... you should check the drip pan for damage (clean the condenser while you are down there) .. also check the tube that carries the condensation (back bottom of the frig) .. it has a one way valve (lets water out only) that becomes stuck sometimes and needs cleaning.. if there is a large amount of moist things in the frig then that an cause the problem as well .. just put those things in plastic bags or containers to eliminate that problem ..
Nov 21, 2009 | Amana AFD2535DES French Door Refrigerator
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaks into the freezer
under refrigerator you soposed to use hot water
Dec 22, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerators Logo
59 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
