My SONY Bravia LCD TV model KLV46X200A ( similar to KDL46XBR2) when power on (1) Green light comes on with noise sound & stay few seconds (2) Sounds cuts off , red stand by light started flashinf 6 times ( once only) & then continue to blink 9 times. Please let me know what board/parts to be replaced to rectify my TV. Hope to receive a favourable reply soon Regards,
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
It's not to complicated, in the newer TVs as well as other things, when you first turn them on the diagnostic circuits kick in [that the first relay you hear click] it sends a signal (low voltage) to all the circuits to check them and make sure there are no problems. If it gets the proper returns from each circuit it kicks out and the full power relay kicks in and powers your set up. This is done to protect others circuits that might be effected by a flaw in a different circuit. What started as a small flaw in a component has gotten worse with use which is normal. Your set is kicking the diagnostic circuits and they are detecting the problem and shutting it down. You have problems with your power board, if the diagnostics circuits were not in place and full power hit the set the power board could possibly put triple or more voltage to some section of another board, thus burning it out also. That's why they started using the diagnostic circuits on TVs, Computers have had them for years. Late model car - etc. I would take the power board out of it and go to shop Jimmy's and enter the part # which will be on the board and order me another one and pop it in and kick back and watch TV again. I don't know what a power board would cost for it but "shopjimmy's" carries high quality boards at a reasonable price. I do caution you on buying a refurbished board, they are tempting but I have never and I mean never seen one hold up very long. As a matter of fact I will not put one into a TV or anything else for that matter. So there is light at the end of the tunnel and it's not the train this time! I only work on the kind of TV that plug into the wall or run on batteries, therefore, I've seen a bunch of them in14 years. Don't worry about getting the wires mixed up because one thing about TVs is a harness or plug will only fit one place and that is where it belogs you can't cross them up.
Gillight
