Question about Cisco Valet Plus M20 WirelessN HotspotRouter
Router alarms when I wire connected 3 apple airports
When I connect the third apple airport to the router, it start to flash the ports lights and the network stops working
  • 47 Answers
SOURCE: Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Posted on Sep 09, 2007
  • 286 Answers
SOURCE: cisco 1721 router serial port not showing any loop.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Posted on Feb 11, 2009
prakas_3p
  • 107 Answers
SOURCE: Point to Point T1 Using Cisco 2800 Routers?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 08, 2010
  • 91 Answers
SOURCE: We just bought a Cisco Linksys E2000 router. We
You may need to update the drivers for the adapters that you have on the desktop.
Posted on Sep 15, 2010
  • 85 Answers
SOURCE: I have a linksys e2000 router and it continually
Try upgrading the firmware. Linksys' website should have the latest version for your router posted there.
Are you able to log in to the web interface for your router? Are you able to ping your gateway address (likely, 192.168.1.1)?
You may also want to try resetting it to factory default.
Posted on Dec 10, 2010
I have a RCA Digital Broadband DHG535-2 modem but my Apple Airport Extreme router does not work, any ideas on how to resolve this issue?
Apple uses airport for its wireless connection, how ever the device where you want to connect to should have the wireless feature embeded to it or you should have a wireless router to distribute the wireless signal, if you are using just a modem which doesn't have capability of distributing wireless signals, the Apple airport will surely not work for it requires a modem to connect to. you need to get a router and connect it in your modem so the Apple will work for wireless as well.
Dec 29, 2011 | Computers & Internet
Connected Airport Extreme wireless router unit to a PC. Airport Utility interface screen shows message: "Airport Utility unable to find Airport wireless devices...." Displays rescan button...
You may contact Windows Customer Service for any kind of help you require. You can also call on Microsoft Windows technical support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5216 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
May 18, 2017 | Apple AirPort Extreme Router
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
Just got a new router (motorola) and airport will
Check your connections:
DSL-modem to telephone-jack (or cable-modem to cable-jack).
Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
Ethernet cable from LAN port on router to WAN port on your Airport.
Cut the power to the Airport, and then plug it back in, so that it restarts.
Apr 17, 2010 | Apple AirPort Extreme Router
Airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Dec 29, 2009 | Apple AirPort Extreme Router
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
I want ot disable DHCP on apple extreme router. Because MS 2008 SBS R2 scans for DHCP servers and fails to config if found an other dhcp server (apple extreme)
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
Mar 16, 2009 | Apple AirPort Extreme Router
Will the router work with Apple Airport?
Yes, Airport is 802.11b compliant and will connect to the wireless router. Configure the Airport settings to connect to the SSID of the router (default SSID is WLAN).
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Cisco Valet Plus M20 WirelessN HotspotRouter Logo
37 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
