Question about Miele CVA615 Espresso Machine
I have a Miele CVA615 and the screen shows "selftest" each time I'm trying to make a cup of coffee. It first starts like it is going to work normally but suddenly stops and the message "selftest" appears. Need help ...Thanks
5 Suggested Answers
  • 5 Answers
SOURCE: Miele cva615 how to make coffee stronger less water
open the door and adjust slide for more grounds, also program prebrewing so it adds a little water to the ground to get them going before the rest of the water is pushed though.
Posted on Aug 15, 2009
  • 177 Answers
SOURCE: I have a Miele CVA615
Hi
I think from memory your boiler heater element is defective.
Posted on Jan 18, 2010
tunde007
  • 2382 Answers
SOURCE: Miele cva615 says "brew unit
Hi, possible that there is WEARING OFF of the bushes in the shaft of the grinder jar section or to the motor section. If you can try to hold the spindle and move , there must not be any play of the shaft nor it must be TOO free. If so the bushes must be reset with the same type. Also check if the motor bush/bearings are faulty or a drop of light grease or oil might give a temporary relief.
Or else you have to get a another one....
Posted on Mar 31, 2011
  • 70 Answers
SOURCE: My miele cva615 makes a
yes
Posted on Apr 05, 2011
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
Problem with Miele CVA615 Espresso Machine Water
Frankly, there are things wrong that are beyond your scope, mainly because of the domino effect in small espresso machines no matter who makes them. There are multiple thermostats instead of a pressurestat, and on and on trying to replicate what a commercial machine does. In a machine like yours, the slightest failure of a gasket throws off everything. There is better containment of problems in commercial machines, but that too depends on what fails first.
My advice, if you are a home user, would be to get a manual pump machine , such as a Pavoni, (which I have lost respect for since they employed plastic pistons,) or if for a small cafe or bar, something like a semi-automatic job plumbed through a filter. Either way, in all honesty and that has cost me dearly, I warn you about this coffee business, because it is a science and an art.
It is not easy to make a good cup of coffee or espresso, especially.
Oct 10, 2013 | Miele CVA615 Espresso Machine
We have a Miele conffee machine. Tried to run the descaling program and now something has gone wrong. There is just a line through the main screen and none of the buttons do anything. Turn on/off at the...
What's the model # ? If it's a CVA615 or CVA610, did you complete the descaling process properly, by performing the final rinse, (re-filling water tank and turning the steam selector on?)
Nov 10, 2010 | Miele Coffee System
I have a miele coffee maker and it says "fill water tank" even when it is full. how do i solve this problem?
make sure there is no calcim built up in the water pipes ofyour machine. soewhere along the lines it gets a wrong reading.
you can run a few cups of vinegar in your coffee machine instead of water, then run a couple of cups of water to get rid of the smell of vinegar.
hope this works
May 01, 2010 | Miele CVA615 Espresso Machine
Miele Coffee Machine CVA615, Other brands of Silicone Grease
the cleaning process intended to degreas the brew unit from the fat contaminated from beans so try to select abeans type with less fat
so the times of cleaning will be less
thanks
Jun 19, 2009 | Miele CVA615 Espresso Machine
Feb 28, 2009 | Miele CVA615 Espresso Machine
What do i do to clear the ''rinse machine'' message?
Fill up the water tank 150%
Turn the "Milk" knop and have two cups underneath that you can empty regulary. Then just wait and the machine will say Rinsing Finished.
Fill up the water tank completely again, and the machine will ask. "Clean Water" press the big cup knop.
Then the machine should say, *SELFTEST*
Nov 12, 2008 | Miele CVA615 Espresso Machine
Coffee not filling to set levels
You have a blockage that needs clearing. try putting on full rinse cycle a couple of times, but if that doesn't work then I'm afraid that you will need to call Miele to repair as it is a bit tricky to clear. Also sounds like you may have used a "coated" coffee bean. These machines can only use a normal bean & not flavoured beans which have a coating (sticky). If you have been using the normal beans only then the rinse may help.
Jul 21, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
27 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
