Question about Electrolux Dryers
Td 75 wascomat dryer wont start - Electrolux Dryers
3 Suggested Answers
  • 205 Answers
SOURCE: wascomat TD75 gas dryer is
HI- If it is electric (220V) you may have a bad plug or outlet that is shorting the circuit breaker. Usually when there is a short in the unit it does not blow the breaker. Leave the breaker off and take the plug out and have a look for any burt or melted parts. If that looks ok then have a Tech look at the dryer, something is shorting or going to Ground and putting enough load to trip the fuse. Wouldn't keep trying to start it. I know, not much info but someone really need to be there to look at it in person. Best regards.
Posted on Sep 24, 2010
richroth
  • 9472 Answers
SOURCE: my wascomat td 30 dryer no have heat(gas dryer) thanks
Check all the thermostats for continuity.
Posted on Dec 01, 2012
Wasco td 75, error code E-15
Although I cannot find anything that explains what error code E-15 means for the TD75, I did find an exchange with a technician that explains what the error code means for a TD30/30. If it is similar, the exchange also describes the areas of machine to check for issues.
Wascomat Dryer td 3030 15 Error Trouble Shootings
Jun 30, 2017 | Office Equipment & Supplies
Tip
Where to find Wascomat Laundry Parts
Laundry Parts Market is a growing online resource for commercial and residential laundry parts. We have a large selection and stock of hard-to-get Wascomat Parts. Shop here http://www.laundrypartsmarket.com/Wascomat_Laundry_Parts_s/1830.htm or email parts@laundrypartsmarket.com if you need a part #.
on Aug 22, 2013 | Wascomat 471 812637
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
Rover 75 2.0 td wont start starts with easy start wont run without it
hi
stop using easy start cos it will polish the cylinder bores and you will lose compression.
you need to do a compression test first and remove / test the gloplugs.
If the compressions are low it will require a rebuild
Jul 11, 2014 | 2000 Rover 75
Td 50 can,t change programming mode
try turning off at wall first for about 30 sec , if still the same it might be sticking buttons or the programer
Apr 15, 2014 | Wascomat Parts Wascomat 169535 Dryer...
Wascomat W-125
Search craigslist, ebay, and google the part number to try and find a used replacement part. Search for refurbished electronic control boards companies online.
Feb 07, 2014 | Wascomat Parts Wascomat 990251...
Dryer vibrates a little
-Make sure all leveler are touch the ground.
Good luck
Mai
Nov 26, 2013 | Wascomat Parts Wascomat 487 243376 Dryer...
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
My wascomat td 30 dryer no have heat(gas dryer) thanks
Nov 30, 2012 | Dryers
Dryers Logo
48 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
