Question about Galaxy Radios DX 939
Blown fuses on galaxy dx 939 after holding mike switch for less than ten seconds
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Try to key it down without the mic attached and see what happens.it could be in the ic or even the final so be prepared to replace them
Posted on Aug 09, 2014
Someone peaked the radio, i want it back to 4 watt, how do i do it
you will need an external watt meter and an alignment diagram. Go to www.cbtricks.com , look up Galaxy, dx939 and click on the radio alignment and it will tell you which variables to turn to get it back to 4 watts.
Feb 01, 2013 | Galaxy Radios DX 939
Galaxy dx 66 will not turn on
reverse polarity diode may be blown .
Oct 16, 2012 | Galaxy Radios DX-66V Base CB Radio
Hi i have a galaxy dx 949 i loss the recevie what part do i change
Sub another mike becuse it is part of the circuit, audio output ic,"sometimes developes crack on case" check speaker,"opens" and finally check small capacitor near the audio output ic.
Mar 30, 2012 | Galaxy Radios DX-979 40-Channels Base CB...
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I have a galaxy 99v when i key the mike the frequency counter jumps around.need help where to locate the problum
sounds like either a bad.mixer crystal or the vco is out.of wacky. if it is the crystal then you can try reseting it. it is a 10.240 crystal. heat the crystal wig a soldering iron for white 8 to 10 seconds. if that doesMr work replace it.
Aug 07, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Need help... is there a way to reset the switch login password?
You can reset it to factory defaults in which case it will have the factory default login.
Reset — Press and hold the Reset Button for less than ten seconds to
reboot the switch. Press and hold the Reset Button for more than ten
seconds to reset the switch’s settings to the factory defaults.
Mar 14, 2010 | Linksys Cisco SLM224G Managed Ethernet...
148GTL Cobra (no tx)
Bad transmitter. You can:
1) take it to a repair shop
2) get a new radio
3) repair the transmitter with a stock replacement transmitter
4) check the inside of the radio, make sure everything is where it's supposed to be
5) make sure that you are using the correct power supply for the unit
If the problem is too extensive and you consider getting a new radio similar to the 148GTL, try the Galaxy DX 2527. It's a BIG radio. But it's production was discontinued. If you can't find a Galaxy DX 2527, try a Galaxy DX 2517, it's similar to the DX 2527, but with less features, but has great sound, I get nothing but good comments when I talk on it. The DX 2527 has an okay transmitter, it doesn't sound all too good by itself, so that's why you have the echo and robot voice changer options.
Hope this helps!
Oct 12, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Very old astatic 525 mike wiring
Hello..maybe not a solution..but a hint..measure red-black for 0 ohms while pushing "ptt button" i think it's ptt...bare and transparent is mike...but you can look at original mike and make the same measurement for finding out what is ptt..the two others is mike ...good luck...Ron
Mar 13, 2008 | Galaxy Radios DX-44V 40-Channels Base CB...
Galaxy Dx-88 HL
anything over 10 amps should be sufficient i would assume. if it calls for a 10 amp fuse anything less than that would be under powering the unit
Nov 07, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy Radios DX 939 Logo
54 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
