Question about Broksonic CCVG1935 19 in. LCD TV
Tv screen keeps going off and on
When turning on tv the screen will go on for a minute then go blank to blue screen .then it will go back in forth doing this
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
The colors red blue shake back and forth on the ws55807 mitsubish
maybe you need to goto menu and auto converge colours..
try degauss feature if avail..
Is it a projection tv if so you may need a flyback anode block for R,B guns.
Dec 16, 2009 | Mitsubishi WS-55807 TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi Surround Sound M-VR800
mine does the same thing.. so far I have no clue other than it may be detecting input from devices like vcr..dvd etc..
Mar 25, 2007 | Mitsubishi M-VR800
Blue screen
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Aug 12, 2006 | Samsung HCN4226W 42" Rear Projection...
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Broksonic CCVG1935 19 in. LCD TV Logo
13 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
