Question about General Electric Washing Machines
General Electric model wwa8350g washer continues to fill passes selected water level.
  • 1073 Answers
SOURCE: washer overflows on any water level selection
check the pressure tube from the tub to the water level switch for a hole or crack in the tube, if none found replace the water level switch
Posted on May 27, 2008
  • 70 Answers
SOURCE: Water pours out the bottom of machine during cycle
Don't get rid of that machine. Those can last 30 years easily, and the stuff you get today cannot compare. You got a bad seal going from the basket to the outside tub. If left go, the motor eventually will short out. You will need to remove the adgitator first, by pulling up hard on it. Then grease the spline before you put it back. A 13mm metric socket (12 point) to take out the bolts holding down the basket. That rubber boot you will see in there is about 12" inches across at the bottom, and about 8" at the top, and looks like that funny hat Goober used to wear on Andy Griffith. The bottom band goes to the tub bottom, and the top goes up against the transmission. The clamps are reuseable, and the boot should be less than $30.00.
Posted on Apr 24, 2009
  • 151 Answers
SOURCE: washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Posted on May 03, 2009
  • 401 Answers
SOURCE: Washer does not spin or drain. It fills with water
This sounds like a faulty lid switch. The washer will do nothing if the lid is open. It is to prevent someone from reaching into the washer while it is washing and spinning. If it is a mechanical switch, you should heara "click" when the lid is opened and closed (almost closed is where it will click). There is a "stub" sticking out on the lid which will operate the switch. Make sure it is not broken off or otherwise too short to push on the switch. If it is a magnetic switch, you'll need to disassemble the unit to get access to it. We will need your make and model to be sure though.
Posted on Dec 30, 2009
Testimonial: "Thanks. It is the lid switch."
  • 153 Answers
SOURCE: general electric top load washer model #wpre6100g1wt loud noise
Your problem could be one of 2 things either the base is pushed up in the center or the front apron is bent. The apron is the piece of metal that runs across under the top cover. To remove the front cover to see either use a putty knife to release the catch between the top and the front cover and pull front outward one side at a time.
Posted on Feb 26, 2010
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Washer continues to fill but never washes, as if a valve has not closed and the water just keeps drianing out of the damned thing.Crappy washer, havent liked it since i bought it.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 23, 2011 | General Electric WJRE5500GWW Front Load...
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Never stops filling with water
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 26, 2010 | General Electric WHDRE526EWW Top Load...
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Aug 14, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not fill with water. have replaced water valve and control board. any suggestions?
If you have replaced the water inlet valve and the control board and the machine still won't fill, then the next logical place that I would look at is the water level switch. This diaphragm like device has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. Make sure the tube is not obstructed or damaged in any way. Check the switch using a multimeter or ohmmeter. Check for continuity. A lack of continuity would indicate a faulty switch. My thinking is that the switch may be stuck, thereby telling the washer that the tub is full already. Hope this helped and best wishes.
Aug 09, 2009 | General Electric WBVH6240HWW Front Load...
We have a GE top load washer with the model number WDSR2120J. It new (almost 13 months old so the warranty has just expired.) When we turn it on, it won't stop filling up when it is full. Bubbles then come...
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling into the washer, then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. Also, the pressure supply tube connected to water level/pressure switch may have a hole in it or a bad connection, or possibly plugged up. This rubber tube must have an airtight seal at both ends to perform properly. be sure to check this item also. Happy to help, Tim.
Jul 01, 2009 | General Electric WDSR2120J Top Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Washing Machines Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
