Oce fx3000 tay #1 showing add paper but paper is present
  • 149 Answers
SOURCE: How can I program my office email address into our
http://www.oceusa.com/main/view_media.jsp?CONTENT%3C%3Ecnt_id=10134198673384683&FOLDER%3C%3Efolder_id=9852723696640444&bmUID=1259426710029
This is operator manual. look up one touch for directions
Posted on Nov 28, 2009
  • 149 Answers
SOURCE: How do I reset the message on Oce fx3000?
open the front door and press clear. drum reset? should come up on screen
Posted on Jan 08, 2010
StevenC82
  • 160 Answers
SOURCE: Xerox Phaser 7700 laser printer problem. Display
If your Xerox phaser 7700 7750 or 7760 is having a Paper Jam at A-Fuser error, this video should help. Good luck
Posted on Apr 06, 2011
SOURCE: OCE 7056 Toner Not Fusing To Paper
Dear, This shows that wrong Toner is added so remove it and put the original one ur problem will be rectified. for Oce 7050 series u may aend me the mail stating ur problem on sanjay5in.competent@gmail.com
Posted on Sep 15, 2013
tinman59
  • 15 Answers
SOURCE: How do you clear the fax memory on a OCE FX3000? Says memory is full. Not connected to a pc just use machine for copies and fax
Check your owners manual. your machine may be out of memory. To free up extra memory, you can turn off
fax storage (see Turning off Remote Fax Options on page 64), print fax messages
in memory (see Printing a fax from the memory on page 46) or cancel a delayed
fax or polling job (see Checking and canceling waiting jobs on page 38)
Posted on Sep 15, 2016
Testimonial: "THANKS BUT NONE OF THEM WORKED. It says no fax jobs. but when I try and send a fax or rec a fax the job status report says out of memory"
Shows status offline wont print
Replace with a new drum, clear your print que. reset network and printer
Aug 20, 2015 | Canon Genuine Oce Imagistics Fx3000...
I changed the cartridge in my oce fx3000 copier and I still get the message "change drum" and it won't work
The toner cartridge is a completely different unit from the drum unit. The drum unit is replaced separately, and is good for about 25,000 pages. The toner cartridge contains the toner powder. The drum actually fuses the toner powder to the paper.
Feb 26, 2015 | Office Equipment & Supplies
I cannot get my oce fx3000 printer to print
After you install the New Drum unit you need to reset the drum counter to be able to use the Oce FX3000 again. Open the front door cover (the one you open to replace the drum or toner ctg.) On the control pabel hit the clear/back key. The display should say something like reset drum? Hit 1 for yes, close the door and you should be up and running again.
Oct 08, 2014 | Canon Genuine Oce Imagistics Fx3000...
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
OCE FX3000 is giving a message of dust on the drum. What do we do to resolve the problem? Is it looking for a new drum?
Unclip the whole printer cartridge and you should see a little blue tab that slides back and for.. Slide the blue tab back and forth servral times then insert the cartridge back into printer
Feb 01, 2011 | Office Equipment & Supplies
Dec 31, 2009 | Office Equipment & Supplies
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Oct 16, 2008 | Office Equipment & Supplies
37 people viewed this question
k24674
