Question about Nikon Cameras
Switch sim card
I put in a sd sandisk sim card into camera and forgot to take it out of my Nikon camera now it wont turn on at all what happed pls help!!!!!11 thanks
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Nikon Expert
  • 305 Answers
Your SD card is for your memory check your battery
this is what you check... turn off your camera Take out you battery charge and replace... Take out your SD card replace it correctly. Remove your lens and replace correctly then turn on camera and walla it works! PS its ok to leave the SD card in the camera. The on and off switch turns on camera with a charged battery ELEMENTRY WATSON.
Posted on Jun 03, 2014
Nick Spirov
  • 35 Answers
SOURCE: sd memory card not read by computer
Reformat the card from the camera. You didn't specify camera model but every digital camera has a menu to format media.
If you don't succeed try to connect your camera to the computer and read the photos.
If that doesn't succeed either take your camera to service.
Posted on Jan 16, 2008
  • 24 Answers
SOURCE: sandisk memory card
Has this card EVER worked with your camera? Since you didn't mention the model number of the Canon, it's possible that you have a compatiblity issue here. Most 4GB SD cards these days are actually SDHC cards, which store memory differently (in sectors, like a hard disc drive, rather than bytes, like your main memory). All SDHC compatible cameras also support SD cards, but cameras sold before the SDHC standard was created will not support SDHC memory cards.
There's a chance that Canon has a firmware upgrade to solve this. You would have to look on the Canon USA web site for this, based on the model number of your camera.
Posted on Jan 20, 2008
SOURCE: problem with Nikon d90
unlock your card. you'll get that message when the SD card is locked.  Lock the card only to prevent deleting photos from it. good luck!
Alberto
Posted on Mar 07, 2009
  • 34 Answers
SOURCE: memory cards wont format, says card is full
Is the write protection enabled on the cards?
Which size having the cards?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
Posted on Jun 09, 2009
SOURCE: nikon d60 - error. turn camera off and on again.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
Posted on Jul 19, 2010
Telling me memory card is write protected
there is a small switch located on the side of sd cards used to lock card so you wont accidently erase data, move it the opposite side
Aug 11, 2012 | Nikon Coolpix L20 L21 L22
Can i transfer the internal memory to an sd card
Yes.
Put the card in and turn the camera on. Press the MENU button. Select the Setup menu (wrench icon). Select "Copy".
Full details are in the "Copy: Copying Between Memory Card and Internal Memory" section of the manual (page 112 in this edition).
Jan 09, 2012 | Nikon Coolpix L110 Digital Camera
Have just purchased a Nikon Coolpix S3000/ Bought a SanDisk 2gb memory card whch will not work just says 'write protected'. Have looked for a switch on side to unlock but there doesnt appear to be one. ...
Hello
The problem is likely to be in SD card
This problem mostly comes with SD cards which have lock switch, your card have no switch at all so using a card reader, format it and put back in camera, hope it works if not it should be in warranty, avail your warranty option and replace it immediately.
Good Luck
hope it helps, if so do rate the solution
Dec 21, 2010 | Nikon Coolpix 4500 Digital Camera
Why won't my Nikon coolpix L1 camera work with my sandisk SDHC card?
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Another possibility- SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Finally, it may be that the card is not formatted. Most come pre-formatted, but there is a format function in the camera that you can try. Formatting deletes anything already on the card.
Dec 01, 2010 | Nikon Coolpix L1 Digital Camera
When I put into my camers Nikon D40 IT SAYS IT IS LOCKED?
I sure hope you mean an SD or an SDHC card, since the D40 doesn't take CF cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 17, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Memory card wont format. I bought a new 4G sandisk memory card but all it says after formatting is the card is full.
The S200 uses SD cards. Your new 4GB card is actually an SDHC card and will not work in the S200. You need to use SD cards, 2GB and smaller.
Jun 02, 2010 | Nikon COOLPIX S200 Digital Camera
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
Nikon coolpix L18 lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 04, 2009 | Nikon COOLPIX L18 Digital Camera
My phone wont recognize my SanDisk 4gb micro sd
take out your sd card, along with your batterry and sim card, put all but the sd back together turn on, then put the sd card back in, if this does not work, you either have te wrong card or your phone has a fault. or you can go to settings and try to find the card in the list.
Oct 25, 2008 | Lands Phones
It doesn't switch ON many times though the battery is charge
I have the same problem. I can only turn the camera on once and then I have to wait a day before it will turn back on.  I discovered that if I take out the SD card, I can turn the camera on. Then (while the camera is on) I put the SD card back in.  It's a pain in the ****, but it works.
Dec 23, 2007 | Nikon COOLPIX L4 Digital Camera
Cameras Logo
29 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
