Question about Sanyo PLC-XL50 Projector
Power light is red and projector will not power up at all, have triewd thermal reset and bulb is fine as is the remote. Power light stays red and wont turn to green.
SOURCE: PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
Hey zrscott388, did you end up replacing the bulb and did that fix it? My Z1 is doing the same thing. I hate to spend 300-400 on a bulb and it doesn't work. The Z5 is going for 1100 new on Ebay. I rather do that than waste money. Please let me know.
Posted on Nov 12, 2007
SOURCE: Sanyo XU50 not coming on after lamp replacement
I replaced the bulb reset the timer and viewed it for a little while 30hr or so., shut it down and now it won't turn back on. I plug it in, the light go from green to red and the fan starts up.
Posted on Oct 04, 2008
projdoc
  • 2237 Answers
SOURCE: power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
Posted on Aug 04, 2009
SOURCE: When turning the projector on, the green power
that usually means that the lamp it`s worn out, you may need to replace it!
Posted on Oct 28, 2009
  • 144 Answers
SOURCE: Sanyo PLC-XU35 won't power up. Lights are illuminated.
correct your main mother board has burnt.
Posted on Jan 31, 2010
I changed the bulb and the power lights wont come on
Certain Mitsubishi projectors have a built in bulb life timer, and are programmed to not allow a projector to power on unless the bulb is replaced and the bulb life timer is reset. Its a simple process:
1) Make sure your projector is plugged in.
2) Make sure the main power switch is on.
3) Hold the left arrow, right arrow, and power button on the control panel of the projector (not remote) for 3-5 seconds.
4) Release...
This will reset the bulb life timer to 0000 and allow for normal power up barring any other unforeseen issues.
Mar 07, 2011 | Mitsubishi HC3000U Multimedia Projector
I am replacing the bulb on my sharp xv-z2000 projector. i replaced it fine but the power light and the bulb light both stay red and i cant even turn the projector on. how do you reset the projector?
Two red lights indicate a problem with the lamp circuitry, i.e. the ballast. This requires a service center to change out a circuit board. Given the cost, it might be time to look for a new projector.
Dec 04, 2010 | Sharp XV-Z2000 Multimedia Projector
I cant get the message lamp life is ending off
Unplug your projector from the power source. Hold down the On/Standby button and the Menu buttons at the same time and plug the power back in as you are holding them down. This will reset the lamp hours used and should remove that message.
May 30, 2010 | Toshiba TDP-S8 Multimedia Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Infocus X1 Projector started with 3 blinking red lights.
Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
Mar 09, 2010 | InFocus X1 Multimedia Projector
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Sharp XG-C50X
Did you reset the lamp hours?
Aug 21, 2008 | Sharp Notevision XG-C50X Multimedia...
Sanyo PLC-XL50 Projector Logo
73 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
