Hard to hold arc welding down hand really sputters bad my machine only has 650 hours On it I was wondering if it doesn't like down hand process or may be I have bad brushes
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › Products › TIG -
www.millerwelds.com › Service & Support
SOURCE: my welder only welds for about 2 seconds then
Is enough for this machine, but probably is not a fuse dedicate it just for this end side.
If you can turn all lights off and other items that might be in use with the fuse. If you can't then upgrade the fuse to a 30amp.
SOURCE: I have a lincoln 140 pro mig welder.I am useing 35
Your Linner of the gun could have a kink in it.
SOURCE: I own a Miller "Sidkick" MIG welder. It has been
Hi:
If everything works but there is no arc; you should check your ground clamp, make sure it is not loose or dirty including terminals and replace your gun's contact tip.
Believe it or not this is a simple one.
If this was useful to you please vote. Thanks
SOURCE: Miller Trailblazer, welds great for about 30
Sounds pretty normal. These units are not rated to weld continuously. They might only be rated at 5-10% for cheap welders and longer for better ones. They are never designed to run continuously. You need to get into the higher end ($$$) before you get that ability.
You can try to blow cool air into the unit to help it cool. Sometimes this can extend the work time.Basically you can try that or work to your temp cut off limit as you have been or upgrade to a better unit. That is about all you can do.
