Question about Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver
I am looking for float valve seal replacement kit for a Living Well Pressure Cooker EPC 660D. Do you carry these replacement kits?
3 Suggested Answers
SOURCE: cook's essentials pressure cooker float valve
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } http://www.wpcookware.com/manuals.asp
look at the pressure cooker section (some other pressure cooker is showing in the photo) use the drop down menu to choose the model number of your cooker and click view, it should download as a pdf (or you can save it as one) on your computer.
Hint: I tried this on firefox and the 'view' button would not work, so you may want to use Internet Explorer to get your manual.
Posted on Dec 28, 2008
  • 1739 Answers
SOURCE: Looking for place to order replacement Seal Ring
Replacement parts for the Wolfgang Puck pressure cookers are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sonner.
Posted on Apr 01, 2011
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Manual for kitchen/living electric pressure cooker
Could I get a PDF copy of the Kitchen Living Pressure Cooker manual? I have lost mine.
Thanks!
Debby
Jan 05, 2014 | Crock Pots & Slow Cookers
I can't get my 17quart pressure cooker to seal. I was looking for an online manuel so i could find out why.
Take the rubber ring out of the lid.
Wash it with warm soapy water.
Dry it.
Oil it with vegetable oil.
Now do you see how the rubber ring has a groove around it on the inside? Push your thumb into the groove and work it around the ring, you're trying to spread the rubber V out.
Put it back in the lid and take it for a test run.
In the future store your cooker with the lid upside down on top, keeping it closed will ruin the seal.
If it still won't seal replace the rubber parts, you can get a kit for your cooker from presto.
Regards
TickMagnet.
Aug 08, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
Looking for place to order replacement Seal Ring for float valve for my old Wolfgang Puck Pressure cooker.
Sep 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Jan 16, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
New gasket for lid required
Bravetti PC107HA is made by Euro-Pro. They have very limited support in USA but I found this web site with a phone number to order parts.
http://www.euro-pro.com/europro/productdetail.aspx?pid=EB25EE6B-F278-4317-ADF3-C0D6DE36CC4C(Euro-Pro+Base+Catalog)
The gasket set has no photo but the photo tag is 100KDS and says
Replacement Gasket Kit 2 Sealing Gaskets, 2 Floating Valve Washers Call 1-800-798-7395 to order
Dec 12, 2009 | Bravetti PC107HA Slow Cooker
Cook's essentials pressure cooker float valve
Dec 20, 2008 | Wolfgang Puck 5-Quart Electronic Pressure...
Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver Logo
Top Wolfgang Puck Crock Pots & Slow Cookers Experts
Sloop Johnb
Are you a Wolfgang Puck Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
