Question about Maytag MHN30PDBWW Washer - High Efficiency, Front Load, Coin-Op Commecial Washing Machine"
MAYTAG F20 ERROR HOW TO RESET - Maytag MHN30PDBWW Washer - High Efficiency, Front Load, Coin-Op Commecial Washing Machine"
2 Suggested Answers
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
How do I reset/clear error codes F20 and F21 on my Maytag commercial washers?
Try to turn off power for 2 minutes and fool the washer into thinking it is new vs suffering a water loss. If that doesn't work see if there is a reset button on the mother board.
May 16, 2016 | Maytag Washing Machines
What can I do to reset may washing machine showing an error word of f20
F20 is a water inlet problem not sufficient water supply. Select power/cancel twice to cancel cycle unplug washer or disconnect power
Check both hot and cold are open completely
All screens a
Jul 14, 2015 | Maytag Washing Machines
F20 error code on maytag epic any idea what this means?
F20 means that the unit isn't detecting water is entering the machine quick enough. When the error code appears if there is little to no water in the tub, then you have an issue with either the water supply to the washing machine or the electronic water valve. If the washing machine fills up about 1/2 way up the door and is overfilling with the water, it means that your pressure switch is faulty and will need to be replaced because it's not detecting that water is entering the machine.
Mar 02, 2015 | Maytag EPICz 3.7 cu. ft. Washer
The display is reading F20 Out of Order. I know that behind the frot panel, there is a way to reset the machine, I just can't remember what does it.
sadly many times when we learn something once we should write it down and put with owners manual . try unplugging it for a few minutes .
Dec 07, 2017 | Maytag Washing Machines
Hi, What does a F20 error mean on a maytag 3000 series?
See this page: http://maytag.custhelp.com/app/answers/detail/a_id/2887/~/display-shows-f20-or-fh---front-load-washer
Your washer water valve inlet screens may be dirty / covered with debris and need cleaned. Some hoses have additional screens installed at the faucett connection depending on who did the install process. Low water pressure will also cause this code.
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Maytag Washing Machines
I have a error code washer mayta f20
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Jul 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
F20 error
troubleshooting with the F20code what it says in the trouble shooting section:
Ff20 (water inlet problem, no water or insufficient water supply)
Select stop twice to cancel the cycle. Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer. Re select cycle and press start.
Sep 19, 2009 | Washing Machines
F20 code
its water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Dec 25, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag MHN30PDBWW Washer - High Efficiency, Front Load, Coin-Op Commecial Washing Machine" Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
