Question about GE Refrigerators
Ge tfx27f "No water flows into icemaker" but water is flowing well out of water filter.
GE TFX A27F Icemaker does not make ice. No Water is flowing into the icemaker but good water flow out of the water filter.
the dr
  • 447 Answers
SOURCE: ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Posted on Nov 19, 2007
hapndnvegas
  • 35 Answers
SOURCE: icemaker and water dispenser not
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Posted on Apr 03, 2008
SOURCE: Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Posted on Apr 29, 2008
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
SOURCE: Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
Posted on Jul 22, 2009
Water flow to ice maker has been reduced to
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | General Electric GSS22JET Side by Side...
Ge profile arctica side by side- ice maker and water dispenser not working..have already replaced the water filter
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Jan 11, 2010 | GE Profile Arctica Stainless Steel Top...
Water seems to be flowing into icemaker fine. When I turn on the icemaker the water flows for a few seconds then stops, I have waited to see if the cycle to dump works and it seems as if it never attempts...
If your freezer temperaures are good i.e. it freezes ice cream and the like, then you need to replace trhe icemaker. Typically, under normal conditions, the icemaker would dump a load of cubes @ every 1-1/2 hours. Icemaker part number WR30x10093 @ $148.00 from Marcone Appinace parts or AP Wagner
Apr 09, 2009 | GE Profile PSI23SGR Arctica¿...
No ice from icemaker
Read the manual and see if the icemaker has a thermostat that prevents the admission of water into the tray if the freezer temp is too high. Also..make sure the ice level bar is down.
Mar 09, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker does not work
Turn the icemaker off for 15-20 seconds at the rocker switch on the side of the icemaker body (square white box)Turn switch back on and immediately press the feeler arm (white paddle) in and out three time. This should start a test cycle. If still no water after it runs through a test harvest cycle (will take about 4-5 minutes), remove the icemaker and look at the ring finger size plastic tube that allows water flow into the icemaker. It is probably full of ice (because of a plugged filter or some other water supply interruption -possibly while you were changing the filter). If the tube is iced up warm it up gently with a hair dryer being extra careful not to get drops of water in the hair dryer nozzle. Do NOT use too high of a heat setting as that tube will melt... complicating things unnecessarily
Dec 19, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge refrige freezer ,water to ice maker.
HI.YOU NEED TO CHECK THAT THE WATER VALVE IS WORKING OK THERE ARE TWO SEPARATE VALVES FOR THE FRIDGE
GOOD LUCK MOHAMED
PLEASE RATE THIS
Oct 19, 2008 | GE Monogram ZDI15C Automatic Icemaker
GE refrigerator, leaking water filter
The area above my water filter in my refrigerator is leaking. I doesn't leak until we run the water in the front of the door or the icemaker runs.I have changed the filer and the problem persists. Is there a part above the filter that needs replaced? The model # is GE TFX26ZPDABB. Thanks.
May 19, 2008 | Refrigerators
Ice maker not working
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
