Question about Toys
I have a orange gun but it says green gun calibration on Big Buck safari
4 Suggested Answers
  • 5 Answers
SOURCE: Big Buck Hunter Pro Arcade game - gun no longer shoots.
Put the game into switch test mode and press the trigger on the n/w gun. If it doesn't register you need to dissassemble the gun as the trigger microswitch has probably failed. You'll need an adapter to remove several security screws. Separate the two halves of the gun carefully as there are springs and other parts that can become displaced and lost. Remove and renew the microswitch adjacent to the trigger. It is a low rolling resistance switch manufactured by Cherry. If you have trouble sourcing one, the same switch is used as a trough switch in modern Stern Pinball machines. You may have to shorten the contact legs on the switch to get it to fit. With care this job can be undertaken by any competent person with intermediate soldering skills.
Posted on Jul 30, 2010
SOURCE: the triger of my gun
Me too! Can't find one, though.
Posted on Dec 27, 2010
SOURCE: i have the big buck
I'm having the same problem. I found that if I put the LED box on TOP of the TV, it will recognize the first target, but not the second or subsequent targets.
It looks to me like this will only work with a smaller TV. The angles seem too large on a big screen TV. I've contacted the manufacturer to see if my guess is right.
Posted on Jan 01, 2011
How to fix an arcade screen on a big buck hunter safari machine?
If the screen appears discolored in the area where it does not shoot then it is possible that you have a degaussing problem( which should be fixed with turning off the machine for a half hour and then back on) or a loose shadow mask in the monitor( which you can do nothing about). Assuming that is not the case then try turning up the brightness and contrast beyond normal and see if it registers. The easiest way to do that is in the tracking screen. If turning up the controls works then you most likely have a bad capacitor in the monitor or on the circuit board. Another possibility would be background light bouncing off the screen. Turn out the lights in the room and try again. Good luck
Apr 27, 2014 | Video Game Consoles & Games
Bad gun boards trying to trouble shoot big buck pro gun boards
after open the gun check also the coil or coils in the target if it is open your gun will no work even if the switch's work properly
Nov 27, 2013 | Arcade Raw Thrills Big Buck Hunter Pro...
Big Buck Hunter Safari Displays "Disconnect" and Dell Computer On/Off Button is Orange, Not Green?
i haven't used my machine in over a year and when I turned it on the first time it said disconnected. I don't know what to do. could someone help please?
Mar 09, 2013 | Toys
I have the big buck hunter pro for my tv, ive tried to do the shootgun calibration from multiple tvs and stood as far back as possible and it still wont calibrate, the menu button will not work either
Dec 25, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
I've lost the instruction manual. How do I set the game up?
Press the test switch inside the coin door. This gives access to the operator menus. Use the start buttons, gun triggers and gun pump handles to move through the menus and select options. It's pretty intuitive once you get in there. First thing is to calibrate the guns, which the game leads you through once you access the relevant menu option.
Jun 14, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
just curious if you still have that broken gun? I am a sculptor in MN and making a piece that i wanted to put a lazor into a broken big buck hunter gun to shoot up at a sensor on a deer which would make it wink at you. thats the plan atleast trying to find a gun. thanks kari
Nov 25, 2009 | Arcade Raw Thrills Big Buck Hunter Pro...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
