Question about Nikon Coolpix 4200 Digital Camera
Camera won't charge
No indication camera is charging
  • 3 Answers
SOURCE: I lost my battery charger and i need to charge my camera battery
you now can buy chargers to replace lost ones, i work in a camera shop and sell a brand called Hanmel. they do a range of the most popular brands of camera chargers, just check the back of the hamnel packaging it to see if it it compatable with your battery
Posted on Apr 13, 2009
SOURCE: Received my new Nikon s6000
Vita, after you connect the camera to the USB cable, make sure the battery door is closed in order for your camera to charge.
Posted on Nov 10, 2010
  • 11967 Answers
SOURCE: As I Purchased a New Nikon Collpix (S3000) camera,
It's not unusual for a defective battery/charger/camera to happen. Take it back and ask for a replacement.
Posted on Nov 11, 2010
SOURCE: i have nikon coolpix p
Hi, possible causes:
Completely exausted battery.
Charger or Usb cable bad.
Fuse open in charge circuit or several damage.
Greethings.
Posted on Feb 19, 2011
  • 1705 Answers
SOURCE: nikon coolpix s80 won't charge
If its under a year old, you should be able to take it back to the vendor for replacement or repair under warranty. You'll need a proof of purchase.
Posted on Mar 03, 2012
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
Nov 13, 2017 | JVC GR Video Cameras
I have charged my batteries for about 4 hrs and inserted into camera but after few minutes it indicates low battery signal
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 29, 2012 | Canon PowerShot A470 Digital Camera
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 15, 2012 | Samsung Digimax L730 Digital Camera
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
Pentax
You can charge the battery using the USB cable. The camera has a built-in recgargeable Li-ion battery, but the AC charger is "optional" ... go figure...
Nice camera, btw...
I'm not aware of any indicator light on the camera. The optional external charger has a red lighht that turns amber, then green.
Aug 26, 2009 | Pentax Optio 30 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Problem with battery,
Sounds like your battery isn't taking a charge so I would say your battery is the problem
Jun 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Nikon Coolpix 4200 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
