Question about Philips SHD8900 Wireless Headphones
SHD8900/79 power switch failed
Slide for power s/w not activating s/w. Just slides bacck & forwards. Can't turn on. Failed when switched off after using.
I have an overhead panel of eight 4' flourescent lights which I believe are each 40 watts. The dimmer switch that controls them all as a unit has failed. Any suggestions about where to get a replacement...
Google-search: florescent slide dimmer
You have 320 Watts, 120 volts, and the circuit uses 2.6 amps.
Volts x Amps = Watts.
1) The florescent slide dimmers seem to cost $100-120
2) If you search for florescent dimmer, the cost is lower than the slide dimmer.
Leviton sells for $50
http://www.google.com/products/catalog
Nov 05, 2010 | RTO Fluorescent Slide Dimmer Switch...
LS error
The machine control detected that the lid switch is not functioning properly. Raise the top part of the washer to gain access to the lid switch.
Disconnect the machine from the power source. Gently pry the emblem from the front of the machine and remove the T20 torx screw hidden behind it. Slide the top of the washer forward and raise its front. Prop it up high enough to allow easy access to the lid switch.
The lid switch is activated by an actuator (part number 19119) mounted on a hinge. It will not work properly if the actuator is damaged.
Check the operation of the lid switch using a multimeter. Disconnect the lid switch wiring harness and connect the test leads of the multimeter (set to X1 or ohm) to the terminals of the lid switch and activate it. The multimeter should read zero ohms while the lid switch is activated and open when deactivated.
Replace the lid switch if it is broken or if it fails the test above. Remove the lid switch mounting screw and install the new lid switch. Reconnect the wiring harness and slide the top of the washer back into position. Reinstall the T20 torx screw and the emblem.
Feb 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The moonroof on my 2002 lincoln towncar is stuck open. I can hear the motor when I push the open button, but the motor sounds dead when I try to push the button to close. Could it be jammed? Is there a...
Temporary Fix: unsnap off the access door in the overhead ceiling liner behind the sunroof opening;
Use a 4mm hexagon Allen wrench to wind it closed.
Sep 12, 2009 | 1999 Lincoln Town Car
Horn and power seats quit working. maxi-fuse extremely hot. pulled it out and re-inserted after it cooled down. fixed the problem temporarily (a day or so). swapped that maxi-fuse with the one above it...
which maxi fuse gets hot ? # fuse , plus amps The power seats uses a 30 amp circuit breaker ,not a fuse . The horn gets power from the same circuit breaker . . Sounds like something is drawing to much current. Do you know how to use a amp meter to test current flow . Disconnect componets till draw goes away ? How to use a wiring diagram to pin point areas in a circuit to test ?
Is there corrosion on the pins where the seat circuit breaker plugs into ? Reach under your seats an see if one of the seat motors is hot .
DeVille
The left and the right power seat system consist of the following components:
• The seat switches
• The seat relay modules
• The 4 reversible motors:
- The front vertical motor
- The rear vertical motor
- The horizontal motor
- The recline motor
These 4 motors operate independently of each other.
When the entire seat switch is pushed to the FORWARD position, the forward input of the of the seat relay is grounded.
The seat relay module supplies battery positive voltage (B+) with a ground to the horizontal motor, in response to this input. In order to drive the seat forward, the motor runs until the switch is released.
The BACK position works similar to the FORWARD position with the exception that the voltage polarity supplied by the seat relay module is reversed causing the motor to run in the opposite direction. This action drives the seat backward.
These recline switches operate similar but independently:
The seat relay module could be bad , If you don't know how to do automotive electrical circuit testing it mite be a good idea for you to take your vehicle to a qualified repair shop.
Could have diagnostic trouble codes stored as well .
DTC B0846 +5 Volt Reference Out of Range
DTC B0856 Battery 2 Out of Range
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1982 Source/Battery Voltage High
DTC B1983 Source/Battery Voltage Low
DTC B2101 Recline Aft Switch Failed (Eldorado)
DTC B2101 Recline Aft Switch Failed (DeVille)
DTC B2102 Recline Forward Switch Failed (Eldorado)
DTC B2102 Recline Forward Switch Failed (DeVille)
DTC B2103 Rear Vertical Down Switch Failed (Eldorado)
DTC B2103 Rear Vertical Down Switch Failed (DeVille)
DTC B2104 Rear Vertical Up Switch Failed (Eldorado)
DTC B2104 Rear Vertical Up Switch Failed (DeVille)
DTC B2105 Horizontal Aft Switch Failed (Eldorado)
DTC B2105 Horizontal Aft Switch Failed (DeVille)
DTC B2106 Horizontal Forward Switch Failed (Eldorado)
DTC B2106 Horizontal Forward Switch Failed (DeVille)
DTC B2107 Front Vertical Down Switch Failed (Eldorado)
DTC B2107 Front Vertical Down Switch Failed (DeVille)
DTC B2108 Front Vertical Up Switch Failed (Eldorado)
DTC B2108 Front Vertical Up Switch Failed (DeVille)
DTC B2109 Lumbar Aft Switch Failed
DTC B2110 Lumbar Forward Switch Failed
DTC B2111 Lumbar Down Switch Failed
DTC B2112 Lumbar Up Switch Failed
DTC B2115 Recline Sensor Failed
DTC B2116 Rear Vertical Sensor Failed
DTC B2117 Horizontal Sensor Failed
DTC B2118 Front Vertical Sensor Failed
DTC B2119 Lumbar Forward/Aft Sensor Failed
DTC B2120 Lumbar Up/Down Sensor Failed
DTC 2130 Seat Motor Failure
Aug 10, 2017 | 1997 Cadillac DeVille
Broken power seat - cannot slide backward. Can I slide it manually?
Ck for debri or other objwcts in way of tracks Does it try to move? If so, there is an obstruction, If not trying or no sound when switch is moved, could very well be a fuse or the forward limit switch is being affected by excess forward travel. Move the switch yo back and without kinda help it. if it's trying.
May 17, 2009 | 1992 Toyota Camry V6
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Sliding Roof Panel Does Not Open or Close
  • Open power feed fuse.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Help with Kenmore washer
most often the lid swtch is out of alignment, less often the switch fails
with the lid open examine the underside of the lid for the plastic 'tooth' that is supposed to engage the switch, if broken or missing replace, test
with the lid open and the washer turned on, use a ballpoint pen to engage the switch plate in the hole at the right side of the lid
If the washer starts, adjust the switch position, test
If the washer does not start
remove the edge trims from the console
remove the screws from the lower corners of the console
slide consloe forward ~1/2 inch, flip up and over
ensure cable is connected to lid switch connector
try lid switch again with ball pen
if washer does not start the switch has failed,
remove metal retainer clips from rear of washer top, remember installed position, you have to put them back
lift washer case 1 inch slide forward, lay down, remove switch
replace
reassemble in reverse order, test
3-5 times a month, takes about 25 minutes, the switch costs $7.95+tax
Aug 02, 2008 | Kenmore 15864/15862 Top Load Washer
IPOD won't turn off.
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jul 19, 2008 | Apple iPod nano
F7 error message
f7 is listed as being a stuck membrane switch for longer than 30 seconds, a button is failed and is stuck in. replacemnet is on ly fix you cant repair active overlay switches
Feb 18, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Philips SHD8900 Wireless Headphones Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
