Question about Garden
Talon am3050 How do you remove the post securing the ignition coil? The bolt at the other side of the coil comes out quite easy, but how do you remove the securing post?
  • Garden Master
  • 2,478 Answers
Does in lift off the post?
Posted on Nov 20, 2013
2 Suggested Answers
BElectric
  • 1140 Answers
SOURCE: how much oil does the sump require in a talon
It's very difficult to find information for this specific mower, however, most petrol mowers have a reservoir size of 1 pint / 0.5 litre. You should have a dipstick for checking the oil level anyway.
Basically, I suggest you drain the sump and add 0.5 litres of oil to ensure that the machine is neither low on oil or overfilled. Then call/email the manufacturer on Monday for clarification and/or a new manual.
Talon Tools contact:
tel: 1300 804 213
customerservice@husqvarna.com.au
Regards,
BElectric
Posted on Nov 06, 2010
How do you remove the ignition coil? I can remove the bolt quite easily, but how do you remove the post which secures the other end of the coil?
would of been very helpful if you would of mentioned the engine you are working on... model/serial numbers would of been even better !!!
Nov 19, 2013 | Mtd 22" Yard Machine Push Mower
How to change ignition control module
There should be 6 bolts that hold the ignition coils in place. If you remove those bolts, the coils and the module will come out. However, if stalling is your problem, I have seen far more failed crankshaft position sensors than ignition modules (although they are quite common as well)
Feb 02, 2013 | 1991 Buick LeSabre
How do I replace the back iginition coils for a 1999 acura tl?
You need to remove the bolt on each coil. Mine was a 6mm allen bolt. Then carefully remove the wires plugged on to each coil. Mine had a small button on the side of the plug/clip that I had to press in to pull the plug off. Then the each coil should slide right out. Slide the new coil in. Reconnect the wires to the coil and put the bolt back in. Done. Quite easy. Just takes a little patients because there is only so much room behind the motor.
Jan 06, 2011 | 2000 Acura TL
How do i change my igniton switch in my 94 acura legend?
To replace ignition switch on 94 legend, first secure the car on a level parking surface, engage parking brake, chock wheels for added safety. Disarm airbags, be aware of a coded radio / sound system, ensure that the 'disarming' code is available or it may be very difficult to reset the radio. Disconnect the Neg. battery cable from the battery post. Remove lower cover panel from lower dash on driver's side. Remove electrical connector from ignition switch. Ignition key must be used to turn cylinder from 'O' to 'I' when necessary to unlock cylinder from column (Steering-Lock Pawl). Remove 2 bolt / fasteners which hold ignition switch in place - it may be necessary to cut a grove into the top of each fastener with a hack-saw or high-speed-cut-off tool if fasteners are the original round-head type. Sometimes simply trying a good pair of locking-pliers with a tight grip will be able to loosten the bolts enough to remove them. Once the old ignition cylinder is removed, clean inside the cylinder opening, install the new cylinder & secure all wiring which was removed, secure switch with new bolts, test switch, replace covers & last of all, reinstall battery connection.
Dec 16, 2010 | 1994 Acura Legend
How do you remove ignition coil from Jaguar S-Type.
Fig. Removing ignition coil plug-3.0L Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. For the right hand bank, remove or disconnect the following:
    Negative battery cable Intake manifold Electrical connector Ignition coil securing bolt Ignition coil
  3. For the left hand bank, remove or disconnect the following:
    Engine cover Electrical connector Ignition coil securing bolt Ignition coil
  4. To install, reverse removal procedure.
Hope helps (remember rated and comment this).
Aug 25, 2010 | 2001 Jaguar S-Type
How many ignition coils are in a 94 cutlass supreme?
You didn't post your engine size so please choose the appropriate one:
Exploded view of the ignition coils and related system components-2.2L engine shown.......2 coil packs
The ignition coils are secured to the module with retaining bolts/screws-3.4L engine shown......3 coil packs
May 23, 2010 | 1994 Oldsmobile Cutlass Supreme
Car quits completely. will not start, goes dead
Remove and clean all battery cable connections to battery and replace bolts
Sep 26, 2009 | 1994 Buick LeSabre
91 eagle talon 2.0 going doun the road quit running,checked coil for spark nothing but i also checked fuel pump an nothing ecsept when u crank the engine shouldnt it pressurise before trying to start?
No spark and no fuel pressure? That sounds like a bad ECU. I would check the ignition coil, and the signal coming from the ECU to the ignition coil. Then I would check the voltage going to the fuel pump. Next, check the timing belt and make sure the correct timing is set.
When you turn your key to the ON position, you should hear your fuel pump pressurize for a few seconds.
Jun 05, 2009 | 1991 Eagle Talon
Ignition Coil A,B,C Primary/Secondary malfunction
Remove the Caravan Ignition Coil Step1 Look under the hood for a distributor. The spark plug wiresmag-glass_10x10.gif connect into the distributor cap. If you don't see a distributor, you may have a model with a distributorless ignition system. Step2 Find the ignition coil. On a Dodge Caravan, the ignition coil is at the back of the intake manifold. Disconnect the negative battery cable to prevent injury while you work. Step3 Determine whether you need to remove the windshield wiper/motor module assembly. This won't be necessary on all models. Step4 Disengage the connector securing the wiring harness connector to the Dodge Caravan ignition coil. Then, disconnect the ignition wire from the ignition coil. Step5 Use a socket set to remove the mounting bolts. There are upper and lower mounting bolts. Separate the ignition coil from the mounting bracket. Install the New Ignition Coil Step1 Insert the new ignition coil. Mount the Dodge Caravan ignition coil to the mounting bracket. Step2 Attach the mounted assembly to the intake manifold. With a Torque wrench, tighten the fasteners securing the ignition coil to the mounting bracket with 96 inch pounds of torque (10 Nm). Step3 Tighten the bolts that secure the intake manifold to the bracket with 115 inch pounds of torque (13 Nm). Step4 Connect the wire harness and any other parts you removed, including the negative battery cable.
Feb 23, 2009 | 1998 Dodge Grand Caravan
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
