Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
TV will not power on
Tried replacing power supply with same results
  • 2 more comments
  • John W Nov 19, 2013
    When I first got it, the original owner said that it did not power on. I plugged it in and it worked fine. Powered it off and then tried to turn it back on and it will not power on. When plugged in, the Vizio logo turns on amber color but that is it. Tried replacing the power supply and still have the same results. Main board issue??
  • John W Jun 23, 2014
    Main board was the issue
    It was the mainboard
    Top Expert:
  • Vizio Master
  • 75,417 Answers
Its main board should be troubleshooted. Contact any service technician. The start signal is not coming to power board, from the main board is the fault. This is not a user repairable one.
Posted on Nov 19, 2013
Panasonic Plasma TV periodically will not turn on.
The power supply section of the tv may be faulty. Open your gadget and check if there are no popped up capacitors. When a capacitor at the power supply section is afftected by a surge, normally it pops up and resultantly affects the switching of the tv ....so check its voltage rating and capacitance and replace with the same value taking note of the polarity of the capacitor
Oct 04, 2017 | Panasonic TC-P46G25 Flat Screen Plasma...
My TV clicked off and will not come back on, When you push the power button, the blue light comes on and then the blue light goes off and a orange light blinks rapidly. I tried unpluging it for 20 mjn....
Your power supply board is dead,do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem
Jun 27, 2011 | Televison & Video
My 32WL66 wont come out of standby???
The tv remote might have a problems.U tried pushing the manual power button on the tv itself also?Yes?Tries tv unplug,replug it back like about an hour later,for the tv resetting itself back to the factory setting.Tv now should be working again.If still have the same result the power supply board is the causes and the problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 18, 2011 | Toshiba 32WL66 31.89 in. HDTV-Ready LCD...
Tried turing on but just keep clicking.. no picture or sound
Tries tv unplug,replug it back about an hour later,by letting the tv resetting itself back to the factory setting.The tv now should be work again.If it have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 01, 2011 | Philips 50PFP5332D 50 in. Plasma...
This TV was unplugged. When it was reconnected there is no power, no little red light near "Turn ON" button. I have tried plugging the TV into alternative outlets with the same result.
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have blown on the power board. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Aug 04, 2010 | Televison & Video
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Installed new Power supply, Monitor stays in standby...? So I noticed my fan was starting to go out, then it actually went out, my power supply would start to over heat and the cpu would shut itself...
Your problem is either the processor or the motherboard. that is why your monitor is not getting any signal. first try to replace the processor because I suspect that this might be the problem as it has gotten overheated before. if there was a power problem with you power supply you monitor would not power up at all.
Jul 10, 2008 | Computers & Internet
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
108 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
