Question about AO Smith Pool & Spa
Mastercraft jet pump model 561471 - AO Smith Pool & Spa
2 Suggested Answers
  • 3519 Answers
SOURCE: My mastercraft jet pump ran dry and will not pump what am I looking for to fix it?
Hi Nick:
Just for fun, try priming it. Remove the Pupe plug with the square head, fill it with water, screw the plug back in, and give it a try.
Posted on May 19, 2015
How do I change my mastercraft jet pump from 230v to115v?
see side schematic for low and high voltage
Aug 24, 2017 | Pool & Spa
Hi Nick:
May 19, 2015 | Miscellaneous
Mastercraft makes sells a lot of pumps. You might want to post with the model number etc. You can also go on line and probably get the manual that will show how it is done.
Apr 30, 2014 | Plumbing
Mastercraft jet pump how do I take it apart for new bearing and seals
There are a lot of different pumps, look in the manual or go on line and get it. If you need more help I would suggest adding the model number etc to your post.
Shallow Water Jet pump will not start
on the pressure switch are the points closed if not its not asking for water.that flat plat under the two screws with springs on them,push down on the plate that will close the points then figure out why its not closing
May 09, 2010 | Plumbing
HOW DO I ADJSUT CUT OFF/ON PRESSURE ON MY ''MASTERCRAFT JET PUMP'' [I MAY HAVE MESSED IT UP] BY TRYING TO ADJUST] CAN SOME ONE HELP ME what happens is that motor keeps on running and after while loose...
Make sure the foot valve in the well is good and the ejecter is cause I have replaced some with a pin hole in them or a rock get in foot valve and not let it hold pressure right.
Pressure Switch the big screw should be the only one you turn to adjust pressure increase or decrease if you moved the small on eyou can look at your old one to get an Idea of where it was set or get you close.
Apr 26, 2010 | Flotec Corrosion Resistant Shallow Well...
Pump will not come up to pressure and turn off!
With no leaks in line and assuming the jet is not embedded in debris at bottom of well, try priming the pump again and getting all the air out.
Jul 05, 2009 | Plumbing
Pool & Spa Logo
223 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
