Question about Mach Speed TRIO Onyx MP3 Player
Onyx When I turn on my player It goes straight voice recorder and it does not let me do anything else. It just stays recording. Please helppppppppppppppppppppppp me !
  • Anonymous Feb 19, 2008
    I have the same problem, you can get out of the recording area, but you'll be kicked back there in a couple seconds
  • Anonymous Feb 26, 2008
    Tried downloading and running the firmware update--no change--player is still stuck in voice record mode....
If you call the tech support line at Machspeed.com they should be able to walk you through flashing your firmware to restore operation.
Posted on Jan 04, 2008
I have the mp3 and just wondering how long you can record voice on it.. ?
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press '<< button to return to the Voice Menu.
Please leace feedback
Cheers
Andy
Jun 04, 2011 | SanDisk Sansa Clip MP3 Player
Purchased this recorder about 6 months ago. Now it can't turn off via the hold switch.A very sleek and convenient piece of apparatus. When I try again after 2 days it works fine but when i try to turn...
It is possible there is an intermittent contact, but I don't believe there is anything to worry about.
The HOLD slider does not turn off the recorder. It only turns the keyboard off and the display off as well. The clock keeps running.
A simple test?
Start a RECORDing operation and slide the switch to HOLD.
(In my VN-1800 the keyboard goes dead, but the display stays on.)
(In my DS-330, the keyboard goes dead and the display goes off.)
If I slide the switch to HOLD during a PLAYBACK operation, it keeps going until the file has finished playing. Then it goes blank.
May 31, 2011 | Olympus VN5000 (512 MB 3005 Hours)...
Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
DS-2300 recorder and DSS player transcription system
try reinstalling the software. And as for the foot pedals, take a good look at them and see if anything's wrong. If you don't find anything then plug it in and out a couple of times and make sure it's snug. For the phone, i suggest you buy a telerecorder. There about 5.35 and you plug into the microphone jack of your recorder and make sure to press record before each conversation on the phone. So far, that's all i can muster up.
Oct 01, 2008 | Olympus DS-2300 Digital Voice Recorder
Help
Your flash memory has become corrupted.. only the manufacturer can repair..I wouldn't try to reformat it...Never force it to run after it has shutdown from low battery. Don't leave it in high heat environment..You could try to connect it to your pc with the power switch in the off position let it charge fully and then before you disconnect turn the power switch on on the player..If thatdoesn't work make sure you are using the pc that connected to the player originally and plug the player with the power switch on and restart your pc. Good luck
Sep 10, 2008 | Mach Speed TRIO Onyx MP3 Player
DS-400 DIGITAL VOICE RECORDER
went on the "menu" option and formated the disk. I first downloaded the files I needed to my computer. Took off the "lock" option.
Jun 25, 2008 | Olympus DM-20 Digital Voice Recorder
Can I use voice record in combination with the timer shut down function?
refer to www.machspeed.com/052manual.zip
depending on the quality you set the player can record for two or more hours..No there is no timer
May 08, 2008 | Mach Speed TRIO Onyx MP3 Player
Help
Hold the menu button (the m button, in the middle), then it will go to the main menu.
Then click on the music button with the "m" but dont hold it then click the play button and then click the volume button wile the sign next to the bar that tells you how long the song is and how long it takes to get done. check the volume if you have it on pause or stop it will go strait to the record button. try it and if it dont work then srry.
Feb 24, 2008 | Mach Speed TRIO Onyx MP3 Player
Mach Speed TRIO Onyx MP3 Player Logo
57 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Gyula Lacz
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
