Question about Splendide ARWXF129W - Washer 24" Whit ARWXF129W
H20 fault code splendide washer
Washer has the h20 fault code
    Master:
  • 238 Answers
Hello!
Seems that a fill valve is broken.
Usually in such cases, a valve replacement is required.
Posted on May 15, 2017
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Fault code h20 flashing on indisit wie127 washing machine
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Please rate my solution.
Thankyou.
Jan 21, 2010 | Indesit W 123 Front Load Washer
Error code H20...My washing machine, a hotpoint wt740 is showing the warning light H20...does anybody know what this means? thanks
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Dec 24, 2009 | Washing Machines
H20 fault is flashing on my hotpoint washing machine all connections are correct but still the machine will not fill with water?
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose/s.
If ti is too low, thjn the valve will not operate properly..
If you are satisfied it is o/k then it is quite likely a valve fault, also check the filter built into the valve inlet.
Dec 08, 2009 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Does not complete cycle comes up with -H20 on screen
Hi.
Fault code H20 is indicating that the washer is not filling correctly, check tap/s hoses, and inlet valves for water supply.
Thanks.
Nov 07, 2009 | Indesit Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
INTERMITANT FAULT
This is a plumbing error and not a machine error. H20 means "water turned off or valve faulty"
Jul 02, 2008 | Hotpoint Aquarius WD640 Front Load...
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Splendide ARWXF129W - Washer 24" Whit ARWXF129W Logo
646 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
