Question about Cell Phones
Air con dead
Split system air con suddenly dead, no stand by light on. Will not switch back on. Circuit breaker did not trip. Need to know where fuse is located.
  • 164 Answers
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Posted on Nov 19, 2013
  • 1 more comment
  • Helen Whelan Nov 19, 2013
    internal and external units are hard wired
  • Charles Ma
    Charles Ma Nov 19, 2013
    Is the air cond for a room or bigger area such as living area?
  • Charles Ma
    Charles Ma Nov 20, 2013
    The fuses, if installed, should be in the unit connected to the power supply/point. The other unit will be connected to the first unit. So if there is no sign of power, as in this case, we need to verify if power is available in the unit that connect to the power supply/point.
Suddenly, turning on my light switch trips the circuit breaker. I tried changing the light switch and it still trips the circuit breaker. How can I fix this problem?
It sounds like the problem is in your light. Leave your circuit breaker in the OFF position, as well as, the light switch. Then, take down the light, or lights...and check out each connection in the light box. It's best to do one at a time, this way you can go by process of elimination. If there's a lot of lights working off this switch. You can disconnect all the lights from the middle of the room. Put wirenuts on all the bare wires, and then try and see if your lights come on without tripping the circuit. If it trips, then you know the problem is further down the line. I'm going to assume there's only one or two lights, so take them down and check the splices (connections). It seems like you have a loose wire at one of the lights. Please feel free to check back with me if you have any further questions. Good Luck! - Jim
Jun 05, 2014 | Leviton Electrical Supplies
Daikin split system air con dead
Split system Air conditioners are very often on two or more separate breakers, with a control voltage (24vac commonly) connecting their operation. the condensor unit and out-door fan generally on a 220 vc 'paired' breaker, possibly a quick disconnect near the unit with fuses inside, or an independant breaker pair, and the evaporator unit with INDOOR fan on a 110 or 220 vac breaker.
switch the fan to 'ON' at the thermostat... this is the midpoint of the system electrically. If the fan comes on check for voltage at the condensor unit. a check to see if the thermostat is the problem... remove the thermostat and connect the red, green and either the white or yellow wires (not both) if you chose white you should have heat...yellow AC...
most split system AC have a small buss fuse on the control circuit board of the indoor unit. looks like a glass tube with metal caps held by metal clips. In 40+ yrs experience I have found it is more likely one or both of the 30 amp buss fuses near the outdoor unit (replace both even if one is still ok) or a 30 amp breaker in the quick disconnect box.
In many systems the control voltage to the thermostat derives from a transformer in the outdoor unit... it could be as simple as a broken wire. Without a full diagnostic, a complete description of the unit ( AC or heat pump, etc) this is all speculation
Nov 19, 2013 | Heating & Cooling
1996 harley 883 headlight flickers off real quick every minute or so with a clicking sound and my front and rear blinkers are dead. I turned it off and pulled out the key and it still made the clicking...
You have a short in your electrical system somewhere that is causing your circuit breaker to trip. Harley uses automatic reset circuit breakers rather than fuses. If you get a short in your system somewhere, the current though the circuit breaker will cause it to trip. After a minute or so, the circuit breaker's bi-metal strip inside will cool and the circuit breaker will reset. If the short circuit still exist, the breaker will again trip.
To help find the source of the problem, you must determine which circuit breaker is tripping. In this case it sounds like the "lights" circuit breaker. Since your turn signals are on that circuit and they are not working, I'd start there to look for the reason.
When you turned off the key and it made the clicking noise again, this was probably the circuit breaker resetting itself after you removed the voltage and current flow through it by turning the switch off.
Good Luck
Steve
Jan 04, 2011 | 2000 Harley Davidson XL 1200 S Sportster...
DEDICATED CIRCUIT BREAKING IS TRIPPING OFF...POSSIBLE CAUSES ARE?
May be compressor struck/Condenser fan motor struck/ short circuit/loose contacts are main reasons for fuse blown or breaker trip.
Dec 11, 2010 | GE Zoneline AZ38H12DAD Split System Air...
My Campbell Hausfeld 13 gallon compressor was working fine then all of a sudden I was losing air in my drill gun and when I turned it off. I tried to turn it back on and it will not turn on?
check your circuit breaker or fuse, then check to see if the compressor itself has a circuit breaker, it may have tripped, if it is humming you may need a new start capacitor, also check your switch
Oct 23, 2009 | Air Tools & Compressors
Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Apr 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
LG S36AHP-UD7 Split Air Con. won't turn on.
Generally when an ac trips the main breaker and the breaker its self isn't bad, the compressor is going bad or is bad. To check you will need to do an ohms test on the compressor. If you get a reading of less than infinite, then the compressor is bad. You will need to test every lead going to the compressor which is usually 3 unless you have a crank house heater installed but they are not typical on a small unit. If the compressor has gone bad it is possible the it took the board out as well.
Mar 31, 2009 | LG Heating & Cooling
Cell Phones Logo
67 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
