Question about DEI GM Immobilizer Bypass
Dynamco 4xr-5 wiring diagram - DEI GM Immobilizer Bypass
Atv wiring diagrams
does it have 4 or 5 wire cdi box . pretty basic but need to know which cdi box it has. help me help you !
Jul 14, 2014 | ATVs
Immobiliser does not work - engine immoblised. Rest of electrics operate normally.
WHEN U SAY WNT START DO U MEAN CRANK OR JUST TURNS OVER WITHOUT RUNNING.. IF IT TURNS OVER AND DOES NOT START IM ASSUMING U CHECKED FUEL PRESSURE. IF SO CHECK UNDER DASH memory fuse. also check ignition fuse
Mar 24, 2014 | 1990 Nissan Pulsar
Spark plug wiring diagram for 05 tahoe
Greg Bernett 2821 Solutions February 14, 2010
You didn't post your engine size so please pick the applicable diagram:
1996-98 4.3L Engines Firing Order: 1-6-5-4-3-2Distributor Rotation: Clockwise
1996-98 5.0L, 5.7L and 7.4L Engines Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise
4.3L Engines Firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
4.8L, 5.3L and 6.0L Engines Firing order: 1-8-7-2-6-5-4-3 Distributorless ignition system (one coil on each cylinder)
5.0L, 5.7L and 7.4L Engines Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Source: spark plug wiring diagram for 98 tahoe
    ledsled378 2926 Solutions July 24, 2010
01f93b7.jpg ..............................
Source: Need diagram for spark plug wiring for 1997 Chevy
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Was this solution helpful? Yes No
    Dennis Weid. 44272 Solutions September 16, 2008
This was all I could come with, hope it helps.
Feb 27, 2013 | 1998 Chevrolet Tahoe
Need wiring diagram for 4xr-5 dynamco immobiliser
hi just want to know I have a 4xr-5 immobiliser on my hyundi exel and I think it not working cause I get no lights on dash when I turn the key, and it use to work. is there any way of bye passing or disconnecting it. thanks luke
Nov 02, 2010 | Car Audio & Video
2002 ford f150 4.2l wiring diagram
The COIL PACK TOWERS are numbered : coil----3---4 pack---2---6 plug----1---5 ----------------------------------------------------------------- The engine cylinders / spark plugs are numbered : passenger side , front to rear , 1 , 2 , 3 -----drivers side , front to rear , 4 , 5 , 6 ------------------------------------------------------------------- The spark plug firing order is ( 1 -4 - 2 - 5 - 3 - 6 )
Apr 07, 2010 | 2004 Ford F150
Got spark plug wires crossed,need diagram
Hope this helps, couldn't find diagram.
Firing order 1-8-4-3-6-5-7-2 --------------- | 2 4 6 8 | | | front | ----- | | | 8 || | | 1 4 || of | |2 3|| | | 7 6 || | | 5 || vehicle | ----- | | | | 1 3 5 7 | --------------- Distributor rotates clockwise
Dec 20, 2008 | 1996 Jeep Grand Cherokee
Diagram for spark plug wires
Firing order 1-6-5-4-3-2
| 2 4 6 |
front | |
| | 6 5 ||
of | | 1 4 ||
| | 2 3 ||
vehicle | |
| 1 3 5 |
Sep 15, 2008 | 1997 GMC Jimmy
DEI GM Immobilizer Bypass Logo
378 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
