Question about Hammering
Wacker jackhammers I have a electric wacker Jackhammer and it stopped working, loss of power and smell of something burning. Also a red light seemed to glow on the front under the plastic. Say on the left front side when holding/operating the hammer.
  • 205 Answers
SOURCE: Jackhammer quit in middle of use
if it is an electric jack hammer the brushes in the motor maybe worn out. most ace hardware stores have a good selection of motor brushes. also check to see if the brush retension screw came loose this would also cause the same problem.
Posted on May 21, 2009
SOURCE: my jackhammer seems weaker than what it should be
my electric 110 kango breaker is working but will not actually break throughits not getting the hammer action,rm.
Posted on Aug 29, 2009
brewerstool
  • 141 Answers
SOURCE: I have a Bosch brute jackhammer, I need the tool
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: switch schematic for a busch brute jackhammer
Go to www.boschtoolsservice.com
Posted on Jan 15, 2011
SOURCE: just bought a new makita jackhammer what is the
I need to check the oil on my machine.. help please
Posted on Mar 03, 2012
I have an electric Wacker jackhammer that is not working, where does it have the brushes?
Most change where the ventilation takes place you can find the commutator of the armature.
Feb 13, 2015 | Hammering
Smelled burning wire and then stopped running
It can also be a suppression capacitor by the switch , or the electric field itself one or both coil fiels are gone.
Mar 29, 2014 | Hitachi DH40MR Jackhammer
Bosch jackhammer
To long without service , or problem with a broken part ? or an problem with a electric field (slide contact somewhere ) or one of the carbon brushes is autostop activated ?
Or simple a cable break , a switch with a problem ,
Mar 27, 2014 | Hammering
Chicago 46935 armature i need 1
Chicago jackhammer 96035 is the same model W/ different accessories. Use this model when ordering parts from Harbor Freight, total cost W/ shipping and tax will set you back about $40.00
Sep 25, 2011 | Electric Demolition Jackhammer
Stopped working suddenly. No PF lights, no smell. Power light turns on sometimes. Fan turns on. Wired properly. No power to sub/subs.
check the fuse holder an the power holder on the inside of the amp an just to see check ur ground some time they lossen
Jun 21, 2011 | MTX JackHammer JH600 Car Audio Amplifier
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
Jan 30, 2011 | Electric Demolition Jackhammer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
I have a old electric 120vac jackhammer (not sure manf.)
usally their is grease packed in the hammer part,you can usally see a plastic type bung(plug)on outter casing
May 13, 2009 | Electric Demolition Jackhammer
Hammering Logo
66 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
