Question about Yamaha HTR-5830 Receiver
Amp switches off at about -10db volume level
The amp switches off at higher volume levels. When I turm it back on, the display reads - " check speaker cables" or something similar. The cable I have used is Monster variety maybe 12 gage even for the center and rears. All speakers are 8 Ohms. All cable lengths are matched for fronts and rears. Thought it was a heat issue - fitted a fan to blow air from top and out bottom - made no difference - got any ideas how to stop this happening ??
  • 1 more comment
  • sun prairie Mar 07, 2008
    HTR-5830 "Check speaker wires" display comes on and system shuts off,
    no matter what volume. Sometimes this happens immediately,
    sometimes after a period of time. Amp is hooked into a whole
    house system. When I substitute an older amp (without the
    protector) it works OK with the house system; also when I hook up the
    HTR-5830 to an old pair of speakers there is no problem. Any
    ideas as to what's wrong?
  • JNVN Jul 29, 2008
    Everything is hooked up correclty...Once I turn the volume up the system shuts down and message appears once you turn the system back on (Chk Spk Wires). Not sure what the problem is??
  • hollytucky Mar 15, 2009
    I have the same problem that Sun Praire had. The receiver shuts off. I have checked all my wiring and find everything is OK. I can not solve my problem as Sun Praire did because my speakers do not have switches that control the volume. What else can I do?? Could the receiver be my problem and not the speakers?? Also I can't get two of the speakers to work. HELP
Sun Prairie here again. I finally solved my own problem, although I never figured out exactly what was causing it. If I keep the volume setting low on the receiver everything is OK. I can still raise the volume at the wall speaker switches without shutting the system down and triggering the Check Speaker Wires message.
Posted on Jun 14, 2008
MAKE SURE NO SPEAKER WIRES ARE TOUCHING OR CROSSED, had same problem. Reciever shuts down to protect the amp.
Posted on Nov 15, 2007
MAKE SURE NO POSITIVES AND NEGATIVES ARE TOUCHING! HAVE SAME RECIVER HAD SAME MESSAGE. IF WIRES ARE TOUCHING EACHOTHER YOU GET THAT. IT SHUTS OFF TO PROTECT YOUR AMP.
  • 93 Answers
I suppose that on all speakers connections + (positive) is on +, and - (negative) is on - ?
Posted on Oct 08, 2007
SOURCE:
The volume of my model's volume only goes up to 40...is there a way to increase the volume?
Sometimes you can connect a lower ohm speakers. However you must NOT go lower than the amp can take. For example if the amp has 8ohm as the lowest for it you can go to 8ohm speakers, if it has 16ohm speakers connected, but must connect 6ohm speakers. If the amp allows 6ohm than you can connect 6ohm speakers. Changing from higher level speakers to lower level ones will make the volume louder. But you must not connect ones lower than the rating of the amp.
The only other way is if there is something wrong with the amp and that it won't go higher due to a fault.
Oct 27, 2017 | The Audio Players & Recorders
Hi Strange problem with Marantz pm7001 When ever I turn the volume upto around 1/3 and 1/2 of the way, the amp cuts out and reset it self down to minimum volume. It seems like the amp ins't enough power...
What's probably happening is that the amplifier is shutting down or cutting back the volume as protection from damage. You may have a partial short in the speaker wiring that is not a problem at lower levels, but at higher ones causes the amp to see too low a load. There may a problem with a speaker or crossover component that is breaking down at higher volumes. Or something in the amp's output stage is unable to handle the load.
Test the system with a known good speaker system and length of wire and see if the trouble continues. If it does, you'll know it's the amplifier that needs to be checked. If the test speakers can reach normal volume, you can start checking the wiring and other speakers for the source of the trouble.
Mar 13, 2011 | Marantz Audio Players & Recorders
What volume level should I set the sub at please. I have a Marantz 7005 av amp and when using Audyssey to set up, the slam from the sub is miniscule. I normally set it a 50% volume when setting up,can...
It might be easier to "skip" the subwoofer meausrement step in Audessy and tune it by ear instead. Refer to page 52 in the manual, step 6/7.
I use familiar music and test tones when I tune my sub to the mains. Generally, I set the preamp trim to -10db, the crossover as appropriate (80 or below), and then bring up the level knob on the sub to taste. Confirm phase alignment, if possible, by having someone flip the phase (if available) so the response is strongest at the main listening position.
Keep it a little "lean" at first, and over the next several hours or days, bring the preamp level up one db at a time. It takes several days of tweaking to arrive at a level that I find appropriate. Once there, I try to ignore programs with bloated bass - remember, not all recordings are created equal.
Should you fond yourself bringing the preamp level to 0 or above, kick the sub amp level knob up a couple of clicks, and back off the preamp level. It's safer to have the amp do the work, than driving too hot of a signal at the preamp level and clipping it.
Jan 18, 2011 | Quad Audio Players & Recorders
I have Bose speakers hooked up with JVC RX668V and the rear speakers aren't loud enough! What can I do to get more volume?
What models of speakers all around? Certain combinations of speaker efficiencies won't be within this unit's capabilities to compensate the volume.
Starting on Page 17 they discuss how you can adjust the Digital Acoustic Processor (DAP) mode to modify the levels of the rear speakers -10dB to + 10dB.
Starting on Page 20 they have similar settings for 5.1 discrete analog inputs.
Mar 01, 2010 | JVC RX-668V Receiver
Logitech quickcam pro 9000. computer does not recognize the microphone. Under devices, not enabled & no drivers, I enable & download drivers, but still no mic. picture great. all other sound...
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Feb 02, 2010 | Logitech Webcam
I try to record a voice message with lifecam vx-1000 but when I try to playback to check the message I don't hear anything. I have checked all the volumes & they're all fine. so why can't I record a...
Set up Audio example
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
Restart computer
Dec 13, 2009 | Microsoft LifeCam VX-1000 Webcam
I have a pioneer gm-x 304 amp. I want to know what are the lpf-off-hpf switches for< and what sdhould I set the input levels to?
Hello packs6,
The lpf-off-hpf switches control the "low pass" and "high pass" filters. When driving full-range or component speakers the filters are usually operated in the "off" position to send all frequencies to the speakers. When driving a subwoofer, the best position is "lpf". If you have a separate amp to power a subwoofer, this amp can be used just for the high frequencies by putting the switches in "hpf".
Input levels should be adjusted to match your receiver output. You don't want the levels so high that distortion results. But you want it high enough for the amp to be able to produce maximum output. Start at about midrange and adjust the receiver volume to a little higher than a comfortable listening level. Adjust the amp gain (level) counterclockwise until you begin to hear the speakers distort. The turn the control slightly clockwise until the distortion disappears. That's the best setting.
Hope this helps.
Sep 02, 2009 | Pioneer Car Audio & Video
I have a Boss OL5KD Class D Monoblock Amplifier and I set it up but is no sound coming up from the speakers, can anyone tell me how to higher the volumen? where is located the volumen??I need to higher the...
Hello maydude01,
The Boss OL5KD does not have a volume control. It has an "Input Level" adjustment which is used to match the output from your head unit preamp output to the amp. It is the first rotary control just to the right of the input jacks.
If you have no sound at all, I'd suspect that something is incorrectly connected or there is no input to the amp. First make sure that the amp power light (green LED) is coming on when you turn on the receiver and that the protection light (red LED) stays off. Then check all of your wiring, especially the RCA output cables.
Initially set the controls like this: MASTER/SLAVE switch in MASTER position (left). INPUT SENSITIVITY 2v-8v (right). INPUT LEVEL, SUBSONIC FILTER, BASS BOOST, and LOW PASS FILTER; midrange. PHASE SHIFT "0" (left). Leave the remote level control disconnected.
After you've checked all wiring and initially set the switches and controls, turn the receiver on to about 3/4 volume. Now adjust the INPUT LEVEL to the left just until you begin to hear distortion, then turn it back right just a little. Adjust the other controls for best sound. Plug in the remote level control and make sure that it adjusts the bass up and down. You're finished!
If there's still no output from the unit after checking all of the wiring, either the unit is defective, it's not getting an input from the receiver, or the sub(s) are defective.
Hope this helps.
Aug 14, 2009 | Boss Car Audio & Video
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha HTR-5830 Receiver Logo
406 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
