Question about Kenmore Washing Machines
Water leak Model# 110.45462500 Water leaking. Removed lower service panel, pump is clean. Water is coming from the backside of the concrete piece where it meets the belly of the drum. Could this be a bad seal? There was a rock stuck in the space behind the rubber on the inside of the drum during a wash cycle, and it made some pretty bad grinding sounds. Got the rock out, but maybe that separated the seal? If so, how would I go about replacing it? If not, what should I do?
    Problem Solver:
  • 11 Answers
Try find the hole and use Silicon to glue it back
Posted on Nov 19, 2013
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
SOURCE: Door seal on GE Adora Washing Machine
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
Posted on Mar 31, 2009
abhishek33
  • 1239 Answers
SOURCE: Water leaking out at bottom of drum during washing and spin cycle
hi it is the problem o outlet valve, clean it...... thank u.......
Posted on Jun 03, 2009
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
Kenmore HE2plus error codes 5d and F21. Already looked at plumbing discharge and found no problems. Can't find a 5d code.
the pump is bad or needs to be cleaned out,open the door and look around the opening you should see a tag with the model and serial numbers ,send the model number,on some of the pumps the middle is removable to clean it out,turn the center piece to the left to remove it but first get a shop vac and vac out any water that's in the tub,then put a towel down or you can use the bottom panel that you removed to get at the pump to catch any water that leaks by.turn the center piece just enough for the water to drain out and vac it up as it comes out until it's empty then unscrew the catch all the way and clean out the pump,if you don't have this kind of pump you'll have to remove the hoses to the pump and check to see if anything is in the pump impellar or the hoses so if you can send the model number i can look it up for you.good luck
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
My washer is leaking water after completing a cycle
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear.
or
The only way to determine where the leak is coming from is to remove the lower kick panel directly below the door. Remove the panel by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then off. If you prop the front feet up this will give you better access (a 2 x 4 works well).
With the panel removed inspect the rubber door bellow. If the front counterweight (gray concrete block on the front of the tub) is wet, the bellow is leaking. Pull the rubber folds back and look for any rips or tears. If the bellow requires replacing, or if you need to simply tighten the clamps, the following link will explain how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
NOTE: Check the plastic dispenser hose on the left hand side of the bellow to ensure it is inserted all the way through the rubber to the flange joint. Sometimes this dispenser hose will slip behind the bellow and allow water to seep inside the cabinet of the washer.
Check the drain pump to ensure the filter cap is secure and not leaking. The pump is in the front directly below the wash tub. If the pump IS leaking, make sure the filter cap is tight and all hose clamps are snug. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Check all hoses the run from the wash tub to the pump, and from the pump to the standpipe at the wall for any signs of cracks or tears.
If the leak is coming from the center portion under the tub, the tub seal is breached and needs to be replaced. This is not an easy repair and will require some extensive disassembly to repair. (Cross that hurdle when the time comes).
Any replacement parts you may need can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. You can use any web source you like, but these I have found, offer great service with competitive pricing. Shop all of them for the best prices. Hopefully you won't need any parts.
Feb 10, 2011 | Washing Machines
Antifrezze leak on passenger side of van at bottom of motor
Possible intake leak and or water pump.If it following the lower hose it is a good chance the pump is leaking.It if follow ing the engine block chances are the intake is leaking.
Dec 06, 2010 | 2001 GMC Safari
Drain reservoir, front loader
If this is a Kenmore Elite series FRONT LOADER, the drain pump reservior is located behind the lower toe panel directly below the door. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. If the pump is damaged and can't pump at the required volume, the drain cycle will exceed 8 minutes and generate error codes. These errors will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are both very simple repairs that you can perform yourself without the assistance of a repairman.
NOTE: For an explanation of any error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back with your MODEL NUMBER. I hope you find this information helpful.
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
Water leaking from front right corner - not hoses
The leak is coming from the area of the drain pump, but you will need to remove the lower toe panel directly below the door to sufficiently inspect where the leak may be coming from. The access screws are located under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. The following link explains what to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Make sure you check all hose connections on the drain pump and make sure the drain pump reservior cap (if equipped) is on tight. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 05, 2010 | Kenmore HE2 Plus Front Load Washer
Our whirlpool is leaking from the bottom during
If you have any questions, please let me know. I hope this helps you.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
On inglis direct drive washing machine excessive lint on clothes and can see no visible lint filter
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 05, 2009 | Washing Machines
HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
