Question about Exercise & Fitness
Dynasizer exercises - Exercise & Fitness
What exercises can I perform using exercise bands?
Using exercise bands, there's a large variety of upper and lower body exercises that you can do. You can do squats, chest/shoulder presses, rows, curls, and many more. For a complete list of exercises and workouts using exercise bands, check out these websites: http://exercise.about.com/cs/exerciseworkouts/a/resistance_3.htm and www.band-exercises.net/exercises/index.html.
Aug 20, 2012 | Exercise & Fitness
What is a fit-tube exercise band?
A fit-tube exercise band is a 4 foot long exercise band with plastic handles. Nice thing about this type of exercise band is that it can be used for exercises like lat pulldown and triceps pushdown which require you to attach the band to the top of a door.
What exercises can be done on the captain's chair?
Using the captain's chair, you can perform a variety of exercises to help you strengthen those abdominal muscles. These exercises include the basic leg raise exercise, captain chair's kicks, and straight leg lifts. For information on how to perform these exercises, go to this website: http://www.livestrong.com/article/89646-captains-chair-exercises/.
Aug 15, 2012 | Exercise & Fitness
Is an exercise bike better than a treadmill?
Both treadmills and exercise bikes give you the benefit of cardio vascular exercise. People, as do I, often prefer the exercise bike over the treadmill because of that the bikes are considerably cheaper than the treadmills and allow you to sit while working out which may allow you to prolong the exercise session.
Aug 09, 2012 | Exercise & Fitness
What are some exercises I can do using an exercise ball?
Here is a list of over 40 exercises using an exercise ball with a description and picture of how to correctly execute each.
http://www.ball-exercises.com/exercises/index.html
Aug 06, 2012 | Exercise & Fitness
What is the benefit of exercising with an exercise ball?
Exercise balls are air-filled and comfortable to use during fitness workouts. They are lightweight and durable. Some of the colorful exercise balls can support up to 600 pounds. It is not uncommon for the exercise ball to be referred to as a Swiss ball, stability ball, gym ball, or a yoga ball.
a. Improve Your Flexibility
b. Improve Your Balance
c. Strengthen the Core Muscles
d. Improve Your Flexibility
turning-your-home-into-a-gym-with-a-swiss-ball_top-image-zr2c4tcbdyndnypnhlbyyv23-3-0.jpg
What exercises can I perform using an exercise ball?
There aredozens of exercises and variations that can be done with the exercise ball.Whether it's core strength, balance, or stability you want to work on, theoptions are extensive. For a complete list of exercises, go to these websites: http://exercise.about.com/cs/abs/l/bl_core.htm,http://www.ball-exercises.com/exercises/index.html,and http://www.fitnessmagazine.com/workout/gear/equipment/best-stability-ball-exercises/.
How many different Exercise Balls are they?
There are plenty of Exercise Balls each serves for a different purpose. Including balance ball, birth ball, body ball, ball, fitness ball, gym ball, gymnastic ball, Physioball, Pilates ball, Pezzi ball, sports ball, Swedish ball, stability ball, therapy ball, or yoga ball.
Aug 02, 2012 | Exercise & Fitness
What is a mini exercise bike?
It is a seat-less exercise bike that can be used to exercise arms and legs. It's also known as a pedal exerciser. See www.miniexercisebikes.com for a list of bikes.
Jul 30, 2012 | Exercise & Fitness
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
Exercise & Fitness Logo
189 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
